Question about Whirlpool Microwave Ovens
Blown fuse on Roper over stove microwave Model #MHE14XMQ-0. Need diagram showing where this fuse is located and how to change out
  • lazer20022 Aug 27, 2008
    My whirlpool mh1140xm microwave/light and vent stopped working. I removed the grease filters to clean them, As I was putting them back, there was a 'blow sound' and the microwave is not working. What could have happened? How can I fix it?
  • Whirlpool Master
  • 9,086 Answers
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Please reply back here if you still need help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
2 Suggested Answers
marked
  • 6487 Answers
SOURCE: Blown fuse on Roper over
Go to this link for the complete detail about your microwave and also for the diagram and how to replace the fuse..
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/0/52015b2c875fae4d85256a8c0062547e/$FILE/4322167.pdf
Hope that helps..........
Posted on Jul 28, 2008
Model:MHE14XMQ-3 light not working even with new bulb. Is there a fuse?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 02, 2010 | Roper MHE14XKB Microwave Oven
Loud fan when microwave model MHE14XMQ is in use
The fan is controlled by control board behind keypad. Replace fan motor first, if that does not help replace control board.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Jan 21, 2009 | Roper MHE14XKB Microwave Oven
How do I remove the wall whirlpool combination of their microwave and oven?
Whirlpool customer service is here and you can enter your model number on that page to download your owner's manual, installation instructions, etc.
The installation instructions will show you how it went up and that will help when you remove it.
Nov 25, 2008 | Microwave Ovens
F6 error... microwave not working
is the microwave itself working? because same thing happened to us apparently the guy who changed the bulb didnt unplugg the thing first and well it burned a part of the circut board cost us about 90 dollars to fix it.....
Oct 05, 2008 | Roper MHE14XKB Microwave Oven
Roper Microwave (mhe14xmq dec. 2003) trips breaker...
you might have to reset your your power settings on the micro.
Sep 21, 2008 | Roper MHE14XKB Microwave Oven
Microwave
It sounds like there may be a blown fuse. The back of the mw oven will have to be removed to check. Some ovens only have a thermal fuse and not a traditional glass fuse. If that is the case you should call a technician to repair it unless you know how to use a soldering iron.
Dec 26, 2007 | Microwave Ovens
Microwave blows fuse
The most common suspects are the high voltage transformer and the magnetron. It's also possible you have a flaky door switch or loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 07, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
653 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
