Question about SharpVision XV-Z9000U Multimedia Projector
Rolling picture I have projector that picture rolls how do i stop this
  • 31 Answers
Have you tested the source machine on another TV or projector. The picture might be rolling before it gets to the projector so you need to verify whether it is the source machine or the content then you might be able to determine if it is the actual projector. Sounds like the vertical sync has got lost somewhere.
Hope that helps. Also we can supply lamps for this model if you ever need.
Re your Sharp XV 9000S We are able to supply replacement lamp+housing delivered (excluding local your local taxes) for $US342 as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens.
http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Posted on Sep 09, 2009
IN VGA input from the laptop, too much noise and shaky rolling black & Blue screen.
seems you burned one line actually A output i would say even input but you have to check line a
Apr 17, 2012 | Sony VPL-ES3 Multimedia Projector
When the projector warms up the picture starts to roll intermitently.
It is possible that your projector has the syncronisation fault in the video processor section. There is a possiblity that the chip is faulty or the corresponding allied cirrcuits have sprung up with some passive component weakness. What you can do is to open the set and warm up the areas near the main chip . Switch on the projector and if you notice the roll had stopped try do it to specific components and finally to the main IC .Replace when you are confirmed but attempt only if you are experienced or seek help to replace. Hope this helps. Good day
Aug 10, 2010 | Sony VPL CS1 Multimedia Projector
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony svga vpl cs1 projector horizontal roll
first of all open the projector and clean it form a bursh then cheack a losing if stips and jumpers thats it
Apr 24, 2010 | Sony VPL CS1 Multimedia Projector
Faint black bar rolling from the bottom
if the bar is black or purple you can try to use a ground lift plug and see if your having a grounding issue.
Jan 15, 2010 | InFocus ScreenPlay 4805 Multimedia...
Screen won't stop rolling out
There is a rubber grommet on the left top of the projection screen, insert the supplied Allen key and turn anticlockwise and adjust turn by turn till the screen rolls out with just 2 to 3" of the black border shows on the top
May 16, 2009 | Draper Baronet 106 in. diag HDTV MW...
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
Tv roll
Are you sure the roll isnt Vertical? as if it is then all you need to do is adjust the VERTICAL HOLD PRESET POT which should be located on the PCB somewhere, its very unusual for TV.S to roll horizontally as then the picture just goes out of sync. and you would not see a picture at all. When you find the pot turn it ( with a small screw driver) slowly until the rolling stops, if it does not stop then you have a faulty component in the vert. sync. circuitry.
Feb 04, 2008 | Televison & Video
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
SharpVision XV-Z9000U Multimedia Projector Logo
185 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
