Question about Siemens Lands Phones
Mms settings for att - Siemens Lands Phones
  • 796 Answers
For getting mms enabled on your phone , you should call the service provider and ask them to activate the gprs on your service number..
only then the mms will be enabled
Posted on Jul 13, 2008
Straighttalk settings for blu phone
try this one
had the problem going through forums trying to find the settings that work for my phone but to no success but I finally figured it out and I'm posting it on here just in case some one else has my same problem.
I had to create two separate APN's one for internet and one for MMS. Settings are as follows:
Internet:
Name: Straight Talk Internet
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: Not Set
MMS Proxy: Not Set
MMS Port: Not Set
MCC: 310
MNC: 410
Authentication Type: PAP or CHAP
APN Type: Internet
APN Protocol: IPv4
Bearer: Unspecified
MMS
Name: Straight Talk MMS
APN: att.mvno
Proxy: Not Set
Port: Not Set
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
MCC: 310
MNC: 410
APN Type: Internet+MMS
APN Protocol: IPv4
Bearer: Unspecified
Do not forget to create two separate APN's!!!!!
goodluck
Jun 23, 2014 | Blu Cell Phones
Need apn settings for at&t straight talk Samsung galaxy discover.model sgh730g at&t4.0.1.1 when first got phone it showed. 4g.phone it blacked out called straight talk they had me changed the apn settings...
Straight Talk AT&T APN Name ATT 4G LTE APN tfdata Proxy proxy.mobile.att.net Port Username Password Server MMSC http://mmsc.mobile.att.net MMS Proxy proxy.mobile.att.net MMS Port MCC MNC Authentication Type PAP APN Type default,mms,supl,hipri APN Protocol IPv4
Sep 11, 2017 | Cell Phones
Att mms setting for lg ku990
This is the configuration of your LG KU990 (Viewty).
Title:
Att
Bearer: GPRS
Auth: PAP
User: WAP@CINGULARGPRS.COM (all caps)
Password: CINGULAR1 (ALL UPPERCASE)
APN: wap.cingular
Browser>Settings>Profiles: (Internet Setting)
Service Name: Media Net
Homepage: http://www.google.com
Connection mode: TCP without proxy
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Messaging>Settings>MMS>MMS center: (MMS setting)
Title: ATT MMS
MMSC URL: http://mmsc.cingular.com/
Connection Mode: TCP with Proxy
Access point: ATT
To get google and all your other java web access make sure that this is the only profile you have in the Access Point. This will default as your java web setting & streaming setting. So you can now stream youtube & use Opera Mini 4.
Best regard:
Henk®Muskita ©2009.
Aug 07, 2009 | LG KU990 Viewty
Mms setting for att
Internet settings for AT&T
Title:
Att
Bearer: GPRS
Auth: PAP
APN: wap.cingular
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Title: ATT MMS
Access point: ATT
Best regard:
Henk®Muskita ©2009.
MMS AND INTERNET SET UP FOR ATT
I also had this problem with my kp500. I found the following site. Entered the data for the GPRS and the MMS and every thing was fine. One note, in the IP address, they omit a number. The address should read "66.209.011.61"
http://www.wirelessgalaxy.com/mobilephones/cingular_wap_and_mms_settings.asp
The KP 500 data is set up on many pages. Setup the Access Point first. Be careful to watch for the case sensitve usernames and passwords.
May 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
I68 no MMS
hi there I have the same exact phone these are the exact settings I have on my phone.
first you will need to create your data account.
select services
select data account
select GPRS
select first entry
edit account name to ATT
press options then press done/ok
edit APN to wap.cingular
edit username to WAP@CINGULARGPRS.COM (UPPERCASE)
EDIT PASSWORD TO CINGULAR1 (UPPERCASE)
AUTH TYPE TO SECURE THEN SELECT DONE AND SAVE.
NOW TO SETUP MMS SETTINGS
select mms then select mms settings
choose edit server profile or edit profile
select the sim card you are using
click edit profile
rename profile to ATT MMS
press options press ok
edit homepage to http://mmsc.cingular.com
edit data account and select ATT
select http and choose http ip address is 066.209.011.032 and the port is 8080
username is WAP@CINGULARGPRS.COM
PASSWORD IS CINGULAR1
SELECT SAVE AND YOU ARE ALL SET, ENJOY YOUR PHONE.
May 05, 2009 | Dual Electronics N99i Cellular Phone
Cannot set up Cingular MMS on LG Prada KF900
hi.
LG prada 2 for ATT
i think i figured it out. but its just to get mms working for pix messaging. if this is what you need, try this. (i have no idea if att charges any fees for doing this or using mms this way. use at your own risk!)
first go to access points under connectivity and add a new access point.
i dont remember why, but i named mine express.
under bearer enter GPRS
under APN ender wap.cingular
save!
then go to internet profiles and add new profile.
name it Cingular mms
turn on proxy
server address enter 066.209.011.032 (setting for samsung d807)
server port is 8080
access is express (if you did what i did)
save!
now under messaging/settings/multimedia message/multi msg centre...
add new... name it att mms
under mmsc url, use http://mmsc.cingular.com
under mms proxy select Cingular mms (if you did what i did)
Save!
hopefully this fixed it! let me know if it helped anyone out.
ive been searching for so long and i finally figured this method out.
i would like to know if this helped anyone at all. email me at Salonn@live.com
Mar 18, 2009 | Cell Phones
Nokia 6085 on att won't send or receive mms/multimedia messages
For the normal at&t apn settings, or also called at&t wap settings, these are the values you should use
APN: wap.cingular
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: wap@cingulargprs.com
Password: cingular1
Server: <Leave in Blank>
MMS proxy: wireless.cingular.com
MMS port: 80
MCC: 310
MNC: 410
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
at&t apn settings 4Gdetails: If you have a 4G phone (e.g. iPhone 5, Galaxy S4, HTC one, etc) you should try using these at&t apn settings 4G. They run faster and more stable connections.
APN: phone
Username: <Leave in Blank>
Password: <Leave in Blank>
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
APN type: default,supl,mms,hipri
Bearer: leave it to the Default one at apn settings Step by Step Configuration
May 12, 2017 | Samsung BlackJack II Smartphone
Need help with my lg shine ke970
Set the homepage to: http://device.home
Set the Bearer: GPRS
GPRS settings:
APN: wap.cingular
User ID: WAP@CINGULARGPRS.COM
Password: CINGULAR1
1. Scroll to and select Proxy Settings and press OK.
* IP Address: 66.209.11.32
* Port Number: 80
2. Press the End call key to return to the standby screen
I found this on the web, its a little different then how I did mine, so here it is in case mine doesn't work for you:
here you go...it works !!!
Phone Setting>Connectivity>Access Point: (Data Setting)
Title: Att
Bearer: GPRS
Auth: PAP
APN: wap.cingular
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Title: ATT MMS
Access point: ATT
Oct 16, 2008 | LG Shine KE970 Cellular Phone
Lands Phones Logo
190 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
