Question about Canon imageCLASS MF5770 All-In-One Laser Printer
Scanner is stuck in one position
Not able to scan or fax
    Habit-Forming:
  • 131 Answers
Paste this address in your browser window, you will find helpful information there
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=124&modelid=11147#SupportDetailAct
Posted on Jul 16, 2008
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Cant get the scanner to work. Do I need a CD to reboot it?
Troubleshoot scanning problems - Windows - Microsoft
windows.microsoft.com/.../troubleshoot-scanning-pr...
Microsoft WindowsI added my scanner to the computer but I can't select it when I use Windows Fax and Scan ... I tried putting more than one picture on the scanner at one time and scanningeach of them to a separate file, but it doesn't work. ... Get the word out.
Scanner won't work on my Hp printer and I can't find a way t ...
Scanner won't work on my Hp printer and I can't find a way to view my ink level. Options. Mark as ... If you get stuck I will help you through it. If this does resolve ...
my scanner won't work - HP Support Forum - 867
Jan 18, 2016 | Office Equipment & Supplies
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Jul 14, 2011 | Visioneer OneTouch 8900 Flatbed Scanner
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Jul 08, 2009 | Office Equipment & Supplies
MY RICOH 2020D PRINTER, IS VERY SLOW AND IT DOES NOT SCANNED AT 20PPM, PLUS THE FAX MEMORY ONLY HOLDS UP 40 PAGES, WHAT CAN I DO?
You must have your resolutions set much higher than the default.
Scanner: Go to "user tools", "Scanner features", "scan Settings", "default Scan settings", "resolution".....set to 200dpi
Fax: Resolution may be set to "detail" or "fine" by default , rather than "Standard" ...is either light lit?
This would dramatically reduce memory capacity.
To set this to default standard resolution is a needlessly difficult task. You can either manually turn it off when sending a fax or change the default "user parameter settings" for the "home position". You can find instructions in the Fax manual (Advanced settings). Download here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/x2016_20/x2016_20en.htm
How to set parameters and understand them (sort of ) is on page 80
How to set home position is on page 86
Mar 09, 2009 | Ricoh Office Equipment & Supplies
Stripe on receiving fax Brother MFC 7820N
I had the same problem, and I just fixed it.  It was a tiny little black dot which was stuck to the glass where the document feeder passes the paper to.  First you need to figure out where the line is on paper with respect to the paper, and just carefully run your finger on the glass to see if there is something on the glass.  I removed it, cleaned the glass, and anything which I run through the document feeder is now fine.  Hope this helps.
Aug 15, 2008 | Brother MFC-7820N Printer
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
Canon imageCLASS MF5770 All-In-One Laser Printer Logo
49 people viewed this question
old marine
old marine
