We are looking for a deflection module and hv splitter for model D52w20 by x2 mfg # 2004 serial E334C30BC. Can you help?
  • 8,617 Answers
The deflectionmodule will be almost impossible to get. However it sounds like you quite possibly only need a flyback 259296 and the HV splitter which are the two most common items to fail. you can get both parts at the following link along with free online tech support so you can repair your set yourself, or they can rebuild your Circuit board. Leave them a email include the model number and what you need.
http://servicemanuals.vstore.ca/
Posted on Jul 13, 2008
I need the schematics of the control module
The model listed is an older set----usually if it HAS the splitter it is up front----but most there is not one as it is part of the high voltage transformer----look on the label on the rear where model number is for a Chassis number, that will tell me instantly if a splitter exists or not PTK-------
Nov 05, 2012 | RCA P52926 52" Rear Projection Television
Light flashes two times then nine times
Take set to a shop===this model rarely gets fixed by a do it yourself person. Common issues include bad high voltage transformer and bad solder connections at that part and around it, also bad HV splitter---etc.
Jun 17, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the h/v splitter on rca hdtv d52w20
remove the front speaker panel and then the center access door and you will see the HV splitter mounted up inside the CRT Pack
Mar 05, 2012 | RCA HD52W56 52" Rear Projection HDTV
Rca D61W20 52 in power supply
If the deflection power board was changed with a known good one . then the HV splitter block would be suspect then followed by a bad CRT next. I would try removing one CRT drive board at a time by letting it hang free wires attached then trying to power up the set if it doesnt power up then try one of the other crt drive boards after reattaching the one you previously unhooked. If the set powers up if any certain CRT board is removed you will know the problem is that CRT. If it doesnt power up then its most likely the HV splitter. You can get replacement CRTs, boards and HV splitters that have warranties from www.tvrepairworld.com
Jan 22, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52" projection tv 3 flashing lights, then powers off
If you see the flyback. That has a large red wire resembling a sparkplug wire. That wire goes into the splitter. There will be 3 more red wires coming from the splitter going to the CRTs. Just take the one wire that goes from the flyback and place that in the glass jar. Now some models have the splitter built into the flyback if thats your vase scenario you will need to replace the flyback. No way to test that properly unless you have a ringer to test it with. let me know how you make out.
Mar 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv repair
HV splitter and flyback are common failure items. Remove the HV lead from the HV splitter that comes from the flyback, Place that into a dry glass jar secured so it doesnt come out. Then try powering up the set if the set powers up without shutting down the splitter is bad.
Mar 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 52'
Most times this symtom is because the HV transformer (flyback) has failed. This part is LL008 on the deflection bd. and unfortunately this deflection bd is no longer available and the transformer must be replaced. It is possible that the HV splitter would be bad and that should be eliminated first. Unless you under stand HV and this process I would suggest that you will need a qualified service professional.
Feb 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tectronf@uol.com.br - Rogerio Franco - BRAZIL
Is this the HV Splitter mounted need the crt's? If so the Part Nomber is 263092 Have not seen this part bad in the model d52w20. Have Replaced alot of IFT Transformer ref # LL008 part # 259296. With a credit card call 1-800-326-0313 Cumberland Electronics. Sending to brazil, unKown.
                                       packman
Oct 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Scenium HD52W140 smoked
Hello Here is a link to get the schematic for this set: http://www.servicemanuals.net/results.aspx?type=SM&brand=424&model=%20D52W20 Thank you
Sep 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
