Question about Garmin StreetPilot 2720 GPS Receiver
GARMIN 200 LOCKED
NEED TO KNOW HOW TO MASTER RESET A GARMIN NUVI 200.
If it's locked and you don't have the code and you "can't" send it back then you probably have a stolen unit. The code is set for a reason.
Posted on Dec 28, 2008
How do i get a passcode a for a garmin nuvi 200 if its lockd and u forgot the code and u cant send it back to da company
Posted on Oct 01, 2008
2 Suggested Answers
  • 504 Answers
SOURCE: garmin nuvi 200 password locked
Resetting the unit, as you discovered, will NOT reset or bypass a PIN entered to protect the unit from unauthorized use. The only ways to unlock a PIN locked Garmin are:
1 - Enter the correct PIN
2 - Take the unit to the location at which the PIN was entered
3 - Send the unit back to Garmin. Be aware, however, if you are not the owner of record, Garmin will NOT return the unit to you.
Posted on Feb 10, 2010
My brother passed away and his wife gave me a garmin nuvi 200 and it has a pin code that know one knows. how can i master reset it so i can use the device
There is no way to perform a master rest to clear the PIN. You either have to have the PIN number or contact Garmin to unlock it for you for a fee. I would first try turning the unit on where your brother lived or where he worked and the unit will not ask for the PIN. This is called the safe location. You can then change the PIN. He probably set the PIN at some place where he knows well.
Feb 15, 2014 | Garmin nuvi® 200 Car GPS Receiver
Tip
Garmin Nuvi 200 Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
_________________________
Garmin Nuvi Hard Reset Here.
Download Nuvi 200 Manuals here.
Download Garmin WebUpdater here.
on Apr 17, 2010 | Garmin nuvi® 200 Car GPS Receiver
Garmin nuvi 200w
reset it with your computer. It might need a hard reset
Jun 02, 2012 | Garmin nuvi® 200 Car GPS Receiver
Locked out of Garmin nuvi
To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1200,1300,1400 or 1600 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings. If you would like to back up your favorites you can find instructions to do so here.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
***Don't forget to VOTE for the guys who take an interest in helping!
Apr 19, 2010 | Garmin nuvi 255W GPS Receiver
Have accidently wiped mapping from garmin sat nav
I can help you fix your Garmin Nuvi 200.
The error message you are receiving about maps is actually a sign of a firmware corruption problem, which just happens from time to time with electronic devices. Updating the firmware of your nuvi will replace the corrupt firmware.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software. Occasionally a nuvi 200 will also need a Hard Reset (preceded by a favorites backup) to bring it back to 100% operation.
I hope that helps.
_____________________________
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 09, 2010 | Garmin nuvi 200W GPS Receiver
What do I need to do to update my garmin nuvi 200 series I don't know where to begin.
I can help you update your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 20, 2010 | Garmin nuvi 200W GPS
Garmin nuvi 200 password locked and i did a master reset but that didnt fix the password problem
Feb 08, 2010 | Garmin nuvi 200W GPS Receiver
My grand daughter locked up my garmin nuvi 200. She does not know the pin number she input. Now I can not use it. Can you help?
You can take it to the location where your granddaughter locked it, and it will unlock by itself (this is called the security location). It will then unlock, and you can reset the PIN.
Otherwise, you have to send it in to Garmin with the original receipt and they will unlock it for you. There is no master password.
Oct 21, 2009 | Garmin nuvi 200W GPS Receiver
My kids locked my garmin nuvi 260w all my screen says is enter pin in i dont know it
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Mar 10, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 200 -- won't power up after plugging into USB & Computer
Found out from Garmin Tech services how to reset the NUVI. Good to go.
Thanks.
Aug 05, 2008 | Garmin StreetPilot 2720 GPS Receiver
Garmin StreetPilot 2720 GPS Receiver Logo
590 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
