Question about Canon Cameras
I have an Elura 90 that has suddenly started to show horizontal lines of different video images at the same time; one will show as a still picture and the other will be the video which I'm trying to show. It only does it on parts of different tapes, not all. I have cleaned the heads several times to no avail.
  • dcludwig Jul 15, 2008
    I'm not sure what was meant by the ok button; I took it to mean the record button. Using the record button I tried this several times with no change. Was this correct or did I mis-understand?
    Genius:
  • 1,226 Answers
There is a line sometimes in the lcd of the camera that can be capture when taking picture. this could be not visible but the camera itself can detect it. try to fix some connection of the lcd to the designate circuit of the camera. or may contact the service center of your camera or maybe the vendor can fix it for you for free.
melnavz
Posted on Jul 15, 2008
  • Canon Master
  • 2,794 Answers
Here is a copy of the manual if you don't have one
Pages 120 and 132 tell you what the ok button is all about.
Has this tape been used more than once?
If so try a different tape that hasn't been previously recorded over. If you reuse a DV tape without erasing it first, that condition can happen.
    Scholar:
  • 135 Answers
Hello sir
If it happens more in bright light than in low light it is caused by the shutter inside the lens not opening & closing properly. If the shutter gets stuck open it will allow too much light to reach the ccd causing the electronics to overload and cause the stripes. Since the video function doesn't use the shutter in the lens it isn't affected.
There is a slight chance the problem could be in the electronic circuit but that isn't as likely as the shutter being the problem.
It would need to be disassembled and the shutter repaired.
thank u
Posted on Jul 13, 2008
  • 790 Answers
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Horizontal lines on LG TV
I hate to give you bad news but about 90% of the time horizontal lines come from a bad panel and if that's the case the set isn't worth fixing as a panel costs hundreds of dollars
Mar 24, 2018 | LG Televison & Video
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
Color/graphics distortions quickly degraded to no picture
This is what you will get right before the 1 red ring shows up on # 4. Do the X-clamp fix. Trust me it works.
Aug 02, 2009 | Microsoft Xbox 360 Console
Permanent horizontal black lines on my 50
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
Jan 06, 2018 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Horizontal lines on display but firewire and SD card work fine
Hello people who face similar problems...
First confirm whether it is a problem with the head assembly/ dirty heads.
Do the symptoms appear only on the camcorder's internal TFT side display or is it visible on an external monitor (connect using the AV cable supplied) and the EVF(electronic view finder) also.
If it is visible on the EVF, TFT Side display and the external monitor then it is definately a case of Bad video heads or the tape guide requires to be aligned or calibrated
Dec 18, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Sony Tv kv 2584 A5
There are no adjustments for this problem,if the unit has been working good for 3 years and suddenly gives you this pix is time to call a qualified technician,among many reasons you might have loose solder conections in the horizontal drive circuit or poor regulation problem in the power supply,if you dont know how and where be safe and call a Technician.
Aug 30, 2006 | Sony KV-32S26 32" TV
Cameras Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
