CHECK TO SEE IF POWER GOING TO COOLANT FAN AND COOLANT FAN THERMO SWITCH.THERMO SWITCH LOCATED BOTTOM OF RADIATOR ON THE LEFT HAND SIDE.IF POWER GOING TO THERMO SWITCH THEN SWITCH IS FAULTY.IF NO POWER GOING TO THERMO SWITCH OR COOLING FAN.CHECK LARGE FAN FUSE IN THE ENGINE COMPARTMENT AND YOU HAVE FUSE 16 IN FUSE HOLDER.IF FUSES GOOD YOU HAVE SHORT IN THE FAN WIRE OR FAULTY FAN CONTROL MODULE.SHAKE FAN WIRES IF FAN WORKS PROBLEM IN THE FAN WIRES YOU HAVE A SHORT IN THE WIRES..
