Question about Dell Inspiron 600M Notebook
Mother board problem (problem turning power on)
Hello Atiqq,
Could you suggest the best stores in NY whom I can approach to fix my mother board problem for dell inspiron 600m laptop at an affordable price.
Thanks in advance,
RK.
    Genius:
  • 2,028 Answers
Try the repair service locator at the home page of Fixya. It will list any of our experts that are available or have shops in your area. I will recommend that you stay away from Bestbuy, they're expensive, and always trying ro sell you more.
Posted on Jul 15, 2008
The radio will only turn on if the power supply is plugged in. Once it is on, it will run of battery for hours. It will no long turn on with just the battery. Tivoli suggested some type of amp issue. Have...
yes its possible <br /> the battery and the power supply have different connection on the main board, battery connector have a Diode that works like a valve when you connect the power supply it disconnect the battery <br /> I can fix this problem <br /> I am in NY - <a href="mailto:doron_c21@yahoo.com">doron_c21@yahoo.com</a>
Aug 20, 2010 | Tivoli PAL Radio
Intel mother board power light is on... but processor not working.. when switch on my cpu. the mother board powerlight displayed.mother fan is only one time run for sec.. processor not on
This is was with me too. I know how to fix it. Remove all cables from your cabinet, i mean like keyboard, mouse, moniter etc. Remove your ram too. Then press your power button from 30 seconds. wait for 10 mins plugin all cables and turn it on. Hope it works for you.
Best of luck.
Jul 22, 2010 | Intel D945GCCR Motherboard
New power supply does not work...is it the motherboard
well there are two ways to to figure out which item is broken first you can hook up the power supply and test the pins in the plug with a voltage tester to see if it has power. I do not recommend this approach if you are unsure of what you are doing the voltage coming from a computer power supply is very dangerous. the second thing you could do is attach a different power supply to *********** board if ti works the mother board is good and it your power supply that is busted. Also make sure to check the back of the power supply and make sure it is set to 110 and 220 voltage because this can cause your power supply to not function correctly. It will be a little red switch on the back that says 110v on one side of it and 220v on the other.
I hope this helped.
Thank you,
Norse
Jul 03, 2010 | EliteGroup L7VMM2 Motherboard
Does not turn on
have you checked the power pack connection if it is well connected to the mother board?
Also, does the fan on the power pack work when you turn on the mother board.
Since its not turning on, then the problem is a power related is problem. Therefore, you need to check those areas that supply power into the motherboard, such as the; power cable/cord, power pack, etc.
I wish you good luck.
Mar 22, 2010 | Computers & Internet
No power wont start up.
check the power adapter if its still working.
If the power adapter is still working, then the fault is from the laptop.
The laptop is having a power problem from the mother board.
I don't think this is a fault you can fix your self. I would advice you take it to a technician to fix the problem.
I wish you the best of luck.
Jan 14, 2010 | Toshiba Satellite 2455-S305 Notebook
My dell was hit by lightning and now i cant get it to boot up
hi there;
really,lightning has a great power voltages supply,thousand of volts was supplied in one strikes of lightning.this depend how much voltage was induces on your computer,mostly your avr and psu might be damage by checking if there is power determining the fans inside avr and psu if running maybe you have the power,and some led light are blinking ,some how to be sure you can use multi tester if you have knowledge on this.basic approach if you have black out screen and good power supply,pull out ide cable of hardisk and cd room from mother board,you can run pc w/o them to check your start windows if will open run your pc if still black screen,take another video card and memory card try to replace them and rn your pc,if windows open fine if not maybe you have damage the mother board from lightning.replacing defective devices can put back your windows open.best regards
Jul 24, 2009 | Dell Dimension 2400 PC Desktop
Device error 22. how would i go about fixing this?
I believe this error code is for the fuser not warming up the heatlamps are probably bad best thing to do is replace the fuser
Mar 21, 2009 | Toshiba DP125F All-In-One Laser Printer
How can i get TOSHIBA A80 satellite mother board for my laptop???
dont you have a warranty??
go to any computer store smthing like best buy or future shop
Aug 27, 2008 | Toshiba Satellite A135-S4527 Notebook
Computer will not turn on, ck power supply it is ok, had computer ck'd at best buy they say I need a new mother board. I would like to find out how much it will cost for my pc.
I went to a local computer store and purchased a new mother board which is all I needed to begin with but no one was willing to tell me how to get one without a charging me for the information on how to purchase a mother board from your company. but thank you anyway.
Aug 11, 2008 | Gateway Computers & Internet
Mother boards
Sorry this has taken long. It was difficult to find this particular motherboard.
Here is one link where you can buy this motherboard
Here is another link.
It's a pleasure to be of service.
Lolita
Apr 21, 2008 | ASUS P4S800-MX Motherboard
Dell Inspiron 600M Notebook Logo
85 people viewed this question
Alun Cox
