Question about Acer Computers & Internet
The power jack on my ACER 5002 went bad (computer only powers from the battery). I have the replacement jack, but am unable to get to the brokenjack after taking the laptop apart. Please could you tell me how to access that portion of the computer. Any help is greatly appreciated.
I replaced the power cord and the problem was solved. Did not need to replace the power jack.
Posted on Jul 18, 2008
Benq joybook lite
Batteries only have a useful life and once it is used up they have to be replaced.
If you can get on the laptop and work without any problems using your AC Adapter and Power Cord then the battery is definitely dead and needs to be replaced.
If you have problems using your computer using the AC Adapter and Power Cord then either your Power Cord is Bad or the DC Power Jack where the power cord plugs into the computer is bad. If either of these two is bad they will not charge a Good Battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 04, 2012 | Acer Aspire Computers & Internet
Acer 4310 power problem
Sounds like your DC Power Jack where the Power Cord plugs into the computer is bad.
If the DC Power Jack is bad, then eventually the battery is going to die and you won't be able to boot your laptop. If the dc power jack is bad, the ac adapter power cord can't charge the battery.
May 20, 2012 | Computers & Internet
My acer laptop power switch lights up but I cant get the screen to come on I have a mouse which i plug into a usb port and it will not light up its like no power is going through it.It was working fine...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Apr 18, 2011 | Acer Computers & Internet
Started up the laptop this morning and all of sudden the power went off and i cannot boot it back up no power
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 11, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 6920 just went off yesterday abruptly. no power with or without the battery. no power when just using the power cord. I tried removing the battery and ressetting the power button ( no luck)....
Take the battery out and short the pins. If this doesnot work than seems your power adapter is problem. It is not charging the battery. Check if your power adapter is OK. If it is ok than looks like the power jack pin is open. Take it to repair center to have the Jacks fixed
May 12, 2010 | Acer Aspire 6920-6621 Notebook
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
Auto hibernated, will not power back up
It's possible that the laptop is stuck thinking it should be resuming from standby but cannot find the data in memory. Remove the battery, unplug the power cord, and hold down the power button for at least 10 seconds. Then plug JUST the power cord back in and try to boot the system. If you still get no response then it's possible that one of your RAM sticks is going bad. With the battery and power cord removed try removing both sticks of RAM. Then try to boot the system again with only the power cord in use and no RAM installed. See if you get some sort of response from the BIOS. Hold down the power button to turn the computer off again, remove the power cord, and then try booting the system with just one of the memory sticks installed. If you can isolate one of the sticks as causing the failed boot, then that stick is most likely faulty.
May 13, 2008 | Acer Aspire 3000 Notebook
Acer 5002 Laptop
Take out the battery plug it in and hit power if it turns on let it boot then turn it off. Place the battery back in and turn it on. That happened with an IBM of mine.
Feb 24, 2008 | Acer Aspire 5002WLMi Notebook
Acer 5002 Laptop
Is there any damage or play at the power jack at rear? Sounds like no power is going in. Are there any light on it? Power adapter maybe be faulty also.
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
