Question about LG WM-2277HW Front Load Washer
LE display about one minute after starting my wash the display screen shows LE. I don't have a munal so I do not know what this means. It just stops at the same point every time and shows the same display. I have cleaned the front filter and spun the drum and everything moves freely in both direction...... Please help...Laundry stacking up :) thanks shannon
  • 2 more comments
  • nyflmami Nov 08, 2008
    after starting the washer its saying LE for no reason what does that mean
  • Shelephanty Dec 25, 2008
    I have the same problem. About 1 minute after the machine starts filling with water it stops and "LE" appears on the control panel. What does it mean and how do I get it to run through the whole wash cycle?
  • tammytam7905 Jan 04, 2009
    i have the same problem
  • piney0112 Jan 07, 2009
    le light is blinking what does this mean or how do i fix it thanks
  • 4 Answers
See other posts titled "LG Tromm WM2277HW will not spin"
Posted on Jul 16, 2008
    Brigadier General:
  • 6,966 Answers
Hi again,
Any developments with the LG washer?
Posted on Jul 13, 2008
  • 21 Answers
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The ball sensor is out of order/defective.
Get the manual here: http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Posted on Mar 01, 2009
I have the same problem. I called the manufacturer when we first got the machine (Aug '06) and they said to increase the soil level to high. This defeats the point of a high efficient machine, but I was young and dumb and it solved the problem, so I went with it. Now that it has been 2 1/2 years, the error occurs more frequently and my warranty is expired. I would NEVER buy this washer again and am VERY frustrated with the the customer service as they talked me out of solving the problem permanently and instead offered a quick, and for them, free solution that now only sometimes works. I am wasting money on water, detergent and most importantly time trying to get my machine to wash normal loads. I would NOT recommend this washer to ANYONE!
Posted on Feb 24, 2009
I have a Samsung washer wf410anwxaa the display shows LE and won't. Start. Change the motor assembly and magnetic and still doing the same.
The manual says LE code means your washer has tried to fill but has not reached the proper water level.
Apr 17, 2015 | Samsung Washing Machines
IT SHOW "LE" WAT DO IT MEAN
Try this and let me know the results.
Unplug the machine for 30 minutes.
Spin the drum by hand a few rounds.
Plug it back in.
Good Luck,
Gary
Jan 13, 2011 | LG WM-2277HW Front Load Washer
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Code "LE"
Here is a tip that will help you understand the LE code...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 21, 2010 | LG WM0642H Front Load
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
I have a LG TROMM washer.It is not washing properly.
LE stands for overload in motor. Wait 30 minutes before restarting. If it happens again try again without a load.Good luck. Please rate me so I know how I'm doing. Thanks.
Dec 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
LE ERROR CODE
This new....just call out LG to repair under warenty!!
Jul 22, 2007 | LG LDF6810 Built-in Dishwasher
LG WM-2277HW Front Load Washer Logo
655 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
