Pen drive has been write protected
A pen drive has been write protected...pls tell me how to inactivate his write protection....???
    Problem Solver:
  • 9 Answers
I had this problem with an old 64MB jump drive. I did some hunting around on HWA as well as Googling other forums. The general agreement seemed to be that the drive was simply dead. I tried changing all the permissions, attrib in CMD, and even logging into Linux as "root" (the equivilent of Microsoft's "Administrator") to no avail. I was able to back the files up to another drive, and they regained their permission settings, but from what I read, the drive was simply dead. There is formating software for each USB on the web. One can google and download it for free inorder to formate the USB
Here is the link:
Posted on Aug 06, 2008
My 8 Gb pen drive now right protected how can i remove the write protection pls.....................Pls..............say the solution
Sep 13, 2011 | SanDisk Sansa e270 MP3 Player
Removing Write Protection
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 | Computers & Internet
Sir i have purchased 8 gb pen drive on 5-08-09 the problem i am facing is that my pen drive is write protected due to which i am unable to use it and i am also unable to format as it shows write protected...
Try this little nifty application
Open this application before you plug any flash drive into your computer.You can either turn on or off write protection in it.
Hope this helps
Aug 11, 2010 | Computers & Internet
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write protected
do you use windows vista or windows 7 OS?
They have a feature to use an external pen drive as a virtual system memory.
Try backing up all your data to your hard drive then full formatting it choosing NTFS system.
If you use OS which are older than Win XP, you need to format it in FAT32 system instead.
Hope this helps.
Sep 09, 2009 | Sony Electronics - Others
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Oct 31, 2008 | iLO (2 GB) MP3 Player
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Write protection
Disengage the hold/lock switch
Jan 11, 2008 | iLO (2 GB) MP3 Player
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
