Hi if you are comfortable opening the tower try to pull the Hard drive out and all memory except one. If you have an extra stick, swap the memory around the see if it will turn on. Bad memory and Hard drives can cause these problems. Not likely Hard drive because it shouldn't get "stuck" on the sony logo screen. If it is none of those worked , then your MB (Motherboard is bad) or processor is bad.
(if its under warranty ) i recommend you call Sony support to service /replace the broken part.
