Question about Canon imageRUNNER C3200 Copier
Canon ir c 3200
Problem code E000001 0004
  • Anonymous Apr 04, 2009
    problem code E000001 0004
    Sniper:
  • 57 Answers
It is a fuser heat error. Try to reset the machine from the error code. If problem persists you have the check the fuser for damage. Could be a thermister, thermoswitch, or faulty heaters. To clear error, service more function/clear/error/ok/ exit service mode and cycle power.
Posted on Jul 14, 2008
2 Suggested Answers
  • 149 Answers
SOURCE: What is error code E000001-0004 and E000001-0010 f...
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller
Posted on Jun 11, 2010
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
I need photo coppier "
I would recomend You the two second hend refurbished iR 3300 Copier ( B&W ) or Ricoh AF 1045/2045 and color clc 3200 for color, for the beginning and if you want later take stronger 50ppm i.e. IR advance 6055 for B&W and IR ADVANCE C2030L.
Hope that helps!
Jul 27, 2011 | Canon imageRUNNER 5000 Copier
Need an ir c3200 service manual for free....
sir pls help me i need service manual of my ir c 3200 pls sent my add thanks sacuan_lynden2000@YAHOO.COM..
Jan 26, 2010 | Canon iRC3100 Printer
Need How-To on calibrating Canon IR-3200...
try under user mode (add.function) cleaning or similar and auto calibration, it will print out 4 test that you need to scann on copier, you just follow the copiers instruction
Sep 14, 2009 | Canon imageRUNNER C3200 Color Printer
Canon ir c3200 copies are shake what i do
Is the copier making a load noise? You may have a broken driver gear in the fixing unit.
Apr 05, 2009 | Canon imageRUNNER C3200 Copier
I have toner of Ir 3100 but I want to use in ir c 3200 is it
Well toner compositions change to work correctly with different developers. If you use the wrong toner/developer in your machine you WILL need a tech to de-contaminate your machine at a hefty price. That is why the manufacturer makes the bottles different, so the customer cannot use the wrong toner in the machine. DO WHAT YOU WILL.. But I advise Strongly against it.
Apr 03, 2009 | Canon imageRUNNER C3200 Copier
Canon IR 3200 Error code e00677-004 no print or copy clears momentarily after reboot, but returns
ok you have a hard drive error problem that is what the code refers to need to replace the hard drive, try to scout around for one out of another machine somewhere and put it in otherwise if you get a new HDD you need to reload all the machine firmware and you will need special tools for that and only canon technicians have access to that stuff,
as i am a canon tech myself
Mar 30, 2009 | Canon imageRUNNER C3200 Copier
IR C320N scaning with MAC OSX
Use the Irc 3200 drivers on the Canon USA
Color imageRUNNER C3200 : Drivers & Downloads
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2269&modelid=8927
Feb 08, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
1,062 people viewed this question
old marine
old marine
