Question about Whirlpool Duet GHW9150P Front Load Washer
$10 fill valve?
I know that you don't want to endorse any particular site, but I'm having trouble finding the mythical $10 replacement fill valve of my dreams -- perhaps I'm searching using the wrong terms? Could you point me in the right direction, please?
  • dland Jul 14, 2008
    If the part number is http://midwestapplianceparts.com/m1_expo..." target="_blank" rel="nofollow" >358276, then, yet again, Google is my best friend: I found it for about $15 at a number of places. It doesn't look exactly like the one for $53 at a well-known "repair clinic" web site, but I'll check it out before ordering.
    In the meanwhile, I've shut off the inlet valves so I can leave the door open and prevent mold growth in these very hot California Summer days.
Not sure about the $10 replacement (i think it was20-30). if you search for "whirlpool washer fill valve" on the net or on something like ebay, you will get something. alternatively you can try searching on the actual part number.
the mount on generic part I ordered was upside down. So i just mounted it to a piece of 1x2 to reinforce it.
Posted on Jul 13, 2008
Find a word with these letters dlycat
Aha, in Anagram Solver
http://anagram-solver.net/dlycat
the answer is 'dactyl', which means
-a finger or toe
-a particular style in poetry
-a mythical alchemist being
Aug 28, 2013 | Computers & Internet
Tried to fill up full tank in 2007 chevy cobalt ls and it wont take anymore than $1.00 before the fuel nozzle clicks and spills gas all over. anyone know what's up?
Hi, sounds like your vent valve is stuck closed. It is supposed to default open, but the spring may have failed. I don't know if you can buy the valve separate from the vapor canister assembly, but I would shop around. The guy at the following post was having trouble finding one: http://www.cobaltss.net/forums/problems-service-maintenance-69/evap-vent-solenoid-100807/
Oct 07, 2011 | 2007 Chevrolet Cobalt Coupe
My Kenmore Elite washer will not fill.
yes there is a water inlet valve . it is the blue valve your water hoses connect to on the rear of the washer, they get sediment built up inside and get stuck , cost $26.50 from Repairclinic.com just go to site .find parts,then type in your model#
Jan 21, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Kenmore dishwasher 587.15163401 won't fill. I checked the float switch with my multimeter and it's working properly. It's registering zero when I touch the terminals and 1 when I activate the switch. ...
The problem was the water fill valve. When set to Ohms, the multimeter never would read zero indicating a problem with the water fill valve. I replaced the part and it works now. Be sure to turn your water off under the sink before taking it off to replace it.
Sep 12, 2009 | Dishwashers
Wont fill, the light comes on and the timmer sounds to be working
D/w's have a fill valve that allows hot water into the tank, a safety float and switch that will cut the power to the fill valve if the water level inside the d/w gets to high. Check if to see if it is gunked up...clean it thoroughly
A DW not filling is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
I know you said it was replaced....the way you ohm them is to remove the power wires and ohm the valve if the needle pegs out or moves considerably the valve is good...
I hope this helps...good luck....the Fang.
Mar 27, 2009 | Kenmore Dishwashers
Water does not flow to upper rack water dispensors for cleaning.
This is often the fill valve.  You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer.  Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
Mar 02, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Freezer problems
this particular refrig has only one temperature control which as you know is loated in the refrig section. but temperature isnt your problem. when the icemaker fill tube freezes up like yours has it is generally a sign of a bad icemaker fill valve. the valve seals will go bad and allow water seepage into the line, this seepage will freeze creating a snowball effect freezing the tube. you can use a hair dryer to remove the ice from the tube, and either replace the fill vlave yourself or have it replaced
btw the fill valve is the part that the other end of the fill tube is connected to on the back/bottom of the refrig in the compressor compartment. Good luck and message me back if you have any questions. Thanks Peyton
Feb 24, 2009 | Hotpoint HTS17BCM Top Freezer Refrigerator
Got an old saeco magic comfort 7/8 years old -
bye a good coffee descaler not vinager follow instruction on it normally fill the water tank leave room for the descaler start the machine open side valve leave it running for 15 second turn it off let it site for 10 to 15 minute after open valve for 30 second let it site for 10 minute and open valve repeat untill empty tank after clean water tank very good that descaler is acid nasty stuff after fill the water tank full of water start machine open side valve empty water tank that its good luck pierre p.s it take a while do descale good but worth it
Jan 02, 2009 | Saeco Magic Comfort Plus Espresso Machine
No water in unit
My dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
Dec 14, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool Duet GHW9150P Front Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
