Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Flash brive wont work
My flash drive is full, but when I put it in the USB port it indicates that there are zero files; however, under the properties it indicates the flash drive is full of data.
The problem wasn't my flash drive, it was the USB cable that ran from my printer to my hard drive. All I had to do was change the location of the USB cable to another location and the flash drive worked after that with no problems.
Posted on Jul 15, 2008
Loaded my 8G Kingston USB. Next day, properties says zero files, zero free space
Which ever it sounds like it has been exposed to a magnetic field, like a stereo speaker.
Gillight
Jun 24, 2012 | Kingston Digital DataTraveler 4000 8 GB...
Im just trying to get my viewstat VS2000working again . need to find where bin and files are to make it work . i have a usb flash drive to put code in VS2000 ,but cant find now been off line for...
if you mean that you cant access
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Mar 25, 2011 | Televison & Video
Have a ASUS Eee PC 1005 (?). My 500GB USB hard drive won't work. Either not recognized at all or disconnects while in use. Error code 43. Does this on more than one computer windows vista and windows 7...
Hi
The issue here is with your USB 500 GB hard drive.So you need to try to connect the same hard drive on any of your friends computer and check if it works.
So try to connect any other USB device like flash drive and check if USB port is functioning properly.
If the flash drive is not getting detected then the permissions have been revoked.
You need to login as administrator, if your are the only user then login with your ID on start up.
Press and hold the Windows sign key( Do not release) and press R key, this opens the run command box.
On the command box, type "inf" and hit enter key
Go to file name " usbstor " and " usbstor.pnf" and right click and go to properties and select security.
Under Group and Names, sellect your login ID and check for permissions at the below of the same screen.
If it is not under full control then USB device will not get detected.
You need to edit the permissions and get full control.
Hope this helps you.
Thank you
Gowtam R
Jan 06, 2011 | Computers & Internet
My imation USB does not work ! When I insert it
scan it with a updated antivirus and then right click on it and explore it when it opens copy all the files in any folder on the drive and then format it and then insert the files
if u have still ur problem then call me
vicky
+919584011072
May 09, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Cannot access files on Kensington 8 GB flash drive
Which operating system are you running ?
A few important bits of information about using faults and fixes on usb drives w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click permissions
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 If you need more help with this post a reply.
Oct 30, 2009 | Kensington Drive Guardian (12000) Floppy...
Sandisk 16 GB USB Drive wont accept large files says disk is full
What is the USB drive formatted as? Look in My Computer then right click the USB drive, select Properties. See what it says under "File System". My guess is the drive is formatted as FAT32. Now FAT32 has a size limitation of 4GB for a single file, which would explain the error. To get over this you need to reformat the USB drive as NTFS. Then it will accept the 6.95GB file. You can format the drive by right clicking it again and selecting "Format" ... choose NTFS from the drop down menu. Be aware that any data already on the drive will be wiped by the format so be sure to back it up before formatting.
Dec 31, 2008 | Computers & Internet
My computer wont detect my USB flash drive
i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Nov 24, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
Install a disk in drive F?
Download this file from PNY to reformat your Flash Drive. It should work after that. Get the file here:
http://www2.pny.com/support/media//Files/06c3418a-bd4a-4a67-a7b7-f4415a58338a/Pre-test_v1.zip
Aug 22, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Im not sure how to fix the problem if you use windows, but if you use a mac then the steps below can help.  I use a mac and followed the steps below and now my flash drive is fully functioning again.
Connect it to the Mac.
Launch Disk Utility from Applications > Utilities.
Choose the drive from the list.
Click on the Erase tab.
In the Volume Format drop down list, choose Mac OS Extended.
If you want to Zero out the drive, choose that option from Security Options.
Click on the Erase button.
Sorry if this didn't help.
Jul 10, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Toshiba 2GB USB Flash Drive Capacity Problem
format the Flash Drive in in slow mode
click on the properties of flash drive
then click on tools then CLICK ON DEFRAGMENT NOW TAB
Mar 11, 2008 | Computers & Internet
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
83 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
