Question about Whirlpool Duet GHW9150P Front Load Washer
In my Duet Whirlpool washer, when I put fabric softener in it doesn't drain into the wash cycle. It just stays in the loading container. The actual laundry soap does, though.
    Genius:
  • 1,036 Answers
This should be a very simple fix for you.
You can remove the dispensing drawer completely - usually by pushing down on a springy tab. Look along the level of the top for the catch.
When removed, give it a good wash in the sink, as there will be a build up of goo in the little syphon arrangement that dips into the softener area.
If it allows you to unclip it, then do, and rinse it out with running water.
Then dry with kitchen towel. You may need to do this twice.
While the drawer is out, give the hole it goes into a spray with kitchen cleaner, and wipe it clean - don't loose your cloth!
Often this is an area that goes mouldy, leading to a musty smell on the clothes.
Click all together and it should work fine again.
Thanks for using fixya,
If this cures the problem, please rate for others to follow.
Posted on Jul 13, 2008
The softer tray will not drain
Front Load Washer Troubleshooting: Clogged Dispenser ...
? 1:13
https://www.youtube.com/watch?v=KqQcyprw8j8
Dec 14, 2009 - Uploaded by ManageMyLife
Can you shed some light on why these aren't draining? ... Thosecompartment will stay filled with water after wash cycle. ...Whirlpool & Kenmore Washer Repair - Fabric Softener is NotDispensing - GHW9400PW1 - Duration: ...
Fabric Softener is Not Dispensing - GHW9400PW1 - YouTube
Nov 28, 2015 | LG WM2240CW Washer
Whirlpool duet sport, fabric softener is not working
you probably have a clogged tube from some old softener that dryed up inside it
Feb 25, 2015 | Whirlpool Duet Sport HT WFW8400TE Washer
How to clean whirlpool duet fabric softener tube
Pour some hot water in it and see if it drains properly. You'll have to run a couple loads without fabric softener to get it cleaned out right.
Oct 19, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How to add powdered Calgon water softener to Whirlpool Duet front-loading washing machine.
try to put it in where the fabric softener goes, just curious why would you put water softener in your machine?
Nov 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loadrer will not pull fabric softener when the rinse cycle begins.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Detergent reservoir won't drain after cycle finished. Water stays in it.
hopefully your using the HE type detergent an fabric softner, an not using but a teaspoon full each. the machine will detect if there is any product left in depenser. an too there will be some water left to keep lines an seals mosit. to keep from drying out so thats normal.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener releasing during was cycle
Call and use your warr. there might be a problem with the timing to release softener. Might be control board.
Oct 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Detergent and fabric softener dispense at the same time
Whirlpool has designed this drawer as a siphon feed and soap and softener go as 1, 2 punch followed by bleach mid cycle.
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal De
