Question about Frigidaire Dryers
How do you reverse the door on a front load dryer. Model #GLE02152ES1
Remove the hinges from the dryer and then unscrew them from the door. Remove the 4 screws on the opposite side of the door so the inner and outer door panel detach. You will also have to remove 3 phillips head screws that hold the door handle to the panel so you can flip it, because top and bottom are not symmetrical. One of the 3 is hidden under the handle, you will see it when the other 2 are off. Rotate the handle and reassemble handle and inner door panel. Put the hinges back on opposite side and also switch the door latch. PS, one glitch is that the light cutoff switch is on the right side, so the door has to seat well to turn it off.
Posted on Jan 01, 2010
Ghw9400pl0 door
Your model doesn't allow for door reversal on the washer due to the electrical with the door lock, but you can the dryer there is a kit you can purchase with the dryer model number
Jan 17, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Can I change the side the door opens?
Unfortunately you cannot reverse the doors on this model. There have only been two front load washers that I know of that had reversible doors, the maytag neptune and amana front loaders. Your matching dryer for this model, I believe has a reversible door, but you'll have to purchase a kit to do it. IF needed maybe you can switch the dryer and washer locations to make them more accessible?
Sorry, and good luck to you!
Jul 03, 2010 | Whirlpool GHW9100L Front Load Washer
Can i reverse the door opening direction on this model? thanks
no you cant but if you have the matching dryer swap machines and reverse dryer door .hope this helps .please rate my response :)
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
The door on my dryer and washer open the wrong way
On these model you can only reverse the door swing on the dryer but not the washer.
Alternatively, you can switch places with the washer and dryer provided the washer fill and drain hoses are long enough and there is enough room without obstructing the dryer exhaust vent .
If you want to know how to reverse the door swing on the dryer, post your model number and I will try to assist you further.
Apr 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to reverse dryer door on Model #FEFB9200ESO
instructions are available here
thanks for using Fix Ya, please take the time to rate this solution.
clarkco
Feb 06, 2009 | LG WM-2277HW Front Load Washer
Door opens on wrong side
I don't think you can on a front loader washer.. on your dryer you can see how they have screw covers for interchanging, but on washer there are none.. sorry.. good luck..
Jan 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Reverse Door
You can't reverse the washer door, only the dryer door.
They don't make the washers reversible because the door latch and wiring harness would have to be relocated to the other side. It just isn't practical from a manufacturing standpoint.
Sorry, Mike
Nov 04, 2007 | Kenmore 43142 Front Load Washer
Dryers Logo
698 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
