Question about Canon ZR25MC Mini DV Digital Camcorder
ZR25MC, DV tape can't be ejected.
I have Canon ZR25MC. Now the DV tape can't be ejected. It just move up or down a little bit when the door opened and closed. I try fullly charge battery or direct plug in. Some body help. Thank you.
  • Canon Master
  • 2,794 Answers
The best way to get it out is take it to a camera shop of Best Buy. They didn't put a manual eject on the player. If you take it into a shop they should know what to do.
Once it's out clean the heads with a DV tape cleaner.
Posted on Jul 13, 2008
Hi I have a provlem, I have a canon xl1 and when I try to open it to tack the mini dv out but the only thing it opens its the door but the mini dv dose not comes out, if someone have some recommendation it...
You have to have a battery attached in order for the camera to eject the tape, also sometimes if you don't open the door all the way it won't eject the tape either. If it's not that the DV deck may be broken and you could send it in to the company or you could pay a local camera repair company to fix it.
Feb 26, 2012 | Canon Photography
My Canon ZR25mc when powered on now immediately bings an alert to EJECT TAPE. When I eject the cassette a bit of tape stays inside the camera. The rollers do not release all of the tape. I cannot do...
This is a fault in the tape transport system can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, adisloged pinch roller or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Apr 26, 2011 | Canon ZR25MC Mini DV Digital Camcorder
I am currently having the same problem with my ZR25MC. The tape just will not eject. It worked once yesterday the very first time I tried it after not using the device for a couple of years.
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Oct 29, 2010 | Canon ZR25MC Mini DV Digital Camcorder
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
Camera wrinkles tapes
try opening the camera and removing the tape.
Are the reel motor tops OK? Does it look like they seat inside the cassette properly or are the tops at a silly angle or missing?
Look at the mech in particular at the tape path. Is there a buildup of muck on any of the posts, head, pinch roller etc?
Clean this off with IPA alcohol on a cotton bud and leave to dry 1st before trying another tape
Dec 12, 2008 | Canon ZR25MC Mini DV Digital Camcorder
Won't Eject Tape
same problem, after you hit eject is pops out and never opens up, to the right of the "push" button is an arm with a spring, pushing it back will open that side, on the left side is a pin with an arm you can move the arm back the pin moves and the other side will open as well, wont fix the problem but will get you your tape back.  I have a very upset wife, we had a jvc mini DV went out one winter change in temp killed it instantly, now our canon has sat a few years and wont work either,  we bought a flip video, it works.
Oct 06, 2008 | Canon ZR60 Mini DV Digital Camcorder
Canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
Sep 09, 2007 | Canon XL1S Mini DV Digital Camcorder
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
Canon ZR25MC Mini DV Digital Camcorder Logo
316 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
