Question about IBM Intel PRO 19K5710 Network Adapter
Not connected to internet
I have a Linksys wireless which works fine from anothe rcomputer and laptop. I have a PC with a direct connect to a port on the router. I can ping from my PC and the tests I run on the PRO/100 all test ok. What is my next step?
The issue was with Zone Alarm and the latest Microsoft update KB951748. This is for people running Windows XP/2000. Temporary fix was to change the firewall panel to medium.
Posted on Jul 14, 2008
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
LInksys WRK54g-wireless connection works fine, but cannot get LAN
You might have faulty LAN ports on your router or your network cable is bad.
Jan 23, 2010 | Linksys Wireless-G Broadband Router
Linskys wireless-g broadband router not connecting to network
first thing, we need to know what this d-link is... Is this a modem? or another router? Can you check its model #, perhaps at the back? How many ports does it have? To verify your internet connection, try connecting your computer to the dlink and check its IP address (Go to Start> Run> type "cmd". On the black window, type "ipconfig"). Do you have internet connection when your pc is straight to the dlink?
I'm thinking that dlink is conflicting with the linksys settings. If it is, we need to change the IP address of the linksys router. Post back what you find out.
Jun 07, 2009 | Linksys Wireless-G Broadband Router
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
Router doesnt connect to internet
This sounds like a problem with your DSL modem, not the router. Try unplugging both devices and wait about 10 seconds. Plug in the modem first and wait about 30 seconds (at this point the Internet light should be on). Now plug in the router and wait another 30 seconds. This problem is normally due to the modem not getting sync. I would try plugging your laptop directly into modem if this doesn't work to see if you then have Internet. If not call your ISP.
Feb 14, 2009 | Linksys Wireless-G WRT54G Router
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a wire...as long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
IBM Intel PRO 19K5710 Network Adapter Logo
416 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
