Question about Samsung Lands Phones
My phone battery died, and I plugged it into the charger over night, and when I woke up in the morning it didn't charge it any. I tried a different outlet, and it still didn't charge.
  • 796 Answers
Actually the batteries should not be over charged..
once the charge is full you should stop charging it more..
it you leave it over-night the battery will lose its back-up
you should try a new battery..
Posted on Jul 13, 2008
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
My lg shine wont turn on. I didnt charge it last night and it died this morning so i plugged it in for a good half hour and it still wont turn on.
Hello Ashlea
First of all make sure that the charger and the cellphone is connected properly to each other. There should be some activity going on in your cellphone indicating that it is really charging. Can you see that activity? If not, try plugging the charger on a different location. If it is possible, try a different charger.
Update me what will happen so we can continue.
Sep 08, 2011 | LG Shine (CU720) Cell Phone
I have an LG optimistic phone that i have had for one month. It has not been dropped or damaged in any way whatsoever and i woke up this morning and the phone had shut off from a dead battery after being...
try to replace battery ,it is not recommended to charge the phone for more than 3 hours... battery might get damage as well as the phone might get power shortage
May 30, 2011 | LG Cell Phones
I have a Storm 9530. One evening I plugged my phone into my wall charger (not computer) to charge and when I woke up the next morning... low and behold the infamous battery with red line showed on the...
It could be the charger, the phone's power interface, or your battery. When you plug the phone in to charge it, does it recognize the charger and show the lightning bolt symbol for charging?
If you use your computer's USB port to charge it instead of the wall charger, does it act any differently?
Aug 16, 2010 | Cell Phones
My phone was working at night, I plugged it into the wall charger while it was still on. I woke up the next morning, disconnected it from the wall charger, and the phone immediately shut off. I plugged it...
Dear Anthony,
It seems that over charging has damaged your gadget's motherboard or battery mechanism. You have to get it serviced. But still you can try by Removing your battery for 1 hr and then after re insert.
Jun 06, 2010 | RIM BlackBerry Pearl 8100
Phone doesn't turn on.
You should not allow the battery to fully drain,it will die sooner.
Remove the battery for 5mins, replace,and then try and turn on the phone.
Apr 07, 2009 | Motorola Mobility RAZR V3
Battery dies really fast
Since it's a new phone, I would suggest checking the outlet the charger is plugged into. The outlet may not actually be charger your phone. If you try another one and the battery still drains quick, I'd definately see if I could return it.
Apr 02, 2009 | LG Vu CU920 Cellular Phone
My LG Chocolate won't charge
seems like the battery is dead. just get a new battery
Oct 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
Lands Phones Logo
205 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
