Question about Refrigerators
Kitchen Aid Fridge problem
I have a similar problem with my refrigerator as some of you other posts. I don't usually see solutions to the posts, just questions so I thought I would write you a note.
My fridge model # is KSRS25ILSS02 - It is a Kitchen Aid Side by Side refrigerator.
My freezer is working fine, my ice machine is working fine, but my fridge is not, it is not keeping the food cold. It has really begun to be a problem this week.
The fridge sounds like it is runnning normally, but I am not completly positive of this.
Any help is appreciated.
  • Paul Bonsell Jul 14, 2008
    I guess I figured it out, seems that the air diffuser is not opening. Seems like a pretty common problem for this model. Thanks for the help.
    Just out of curiousity, is there regulations against public answers. Or is it a consideration from the website owners. I think it is great that you are protecting skilled trades. I am just used to seeing replies on post, that's why I asked.
    Thanks again.
  • erich_hoang May 14, 2009
    The freezer is working fine, but the fridge is not cool it stays around 70 F. The air is not flowing out of the damper and it started putting out air after I tapped on it. The air is coming out from the damper is very weak and it's not enough to cool the fridge. Should I remove the damper and clean it or replace with the new one? How do I remove it from the fridge? Thank you so much for your help.
    Eric
    President:
  • 1,314 Answers
Ok first the freezer does all the cooling for the whole unit and in order for it to cool properly the freezer needs to be a certain temp it should be around -10 -6 if its not reaching that temp it will still freeze and apper to be working right also check to hear if the freezer fan is running as it pulls air from the fridge and cools it then blowes it back look in the freezer on the back wall toward the bottom see if frost is building also in the refridgerator section on the left hand side of the cabnit is a return vent make sure its not blocked and see what the thermostat in the freezer is and let me know we need to know things like this to help narrow the promblems and people dont reply to the questions so we cant answer appliance repair is a skill
Posted on Jul 13, 2008
  • robert samples Jul 14, 2008
    im not totally sure what you mean but the problem here is so many don't reply they expect a first time answer appliance repair has to work by symptoms like your problem it could have been several things only way to narrow it down is to explain how the unit works and ask questions as im here to help you fix it tech here are volunteers as you can see im a guru in my ranking we get our ranking here by how many people rate us if we answer a question like for you and i get rated my status goes up if i advise you and you just fix it and don't rate me it lowers my ratings we have been dealing with the webmasters on this for awhile i have 502 people never bothered to reply out of 1100 or more some times people come on for a live chat those pay but you have to be a wiz or higher to answer one so a lot of the techs are protecting their ranking from the people who don't reply as for me i don't let that bother me im here to try to help people fix their appliances im glad you found yours we would have gotten to the air flow once i eliminated the system as being at fault like a defrost problem but if i said it was just this and it wasn't you would have been mad at me hence the questions ive been doing appliance repair for 16 years and i try to answer as many a day as i can but its kinda of a let down when people don't reply hope this helps explain a little if you have a skilled Field you can join this site too its free and you could help i think its a great site but its still young and thanks for the rating
Kitchen Aid fridge Mod# KSRS25ILSS02
Initially, pls try to verify if the blower fan is working. Its function is to draw cold air from the freezer side and vent it to the fridge side. Additionally, pls check if the air pathway is block or obstructed. Pls post back results of checks.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 17, 2008 | Refrigerators
Tip
Important Info need when asking a question about your Major Appliance
Please get the model From your appliance before you post your question. We can not do a thing for you with out that model. Thanks you so much. We are trying to help you.
on Mar 15, 2015 | Electrolux 78956 Frigidaire GE Maytag Jenn...
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
Jan 28, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
Refrigerator motherboard How can I tell if the motherboard of my kitchen Aid refrigerator went bad
Make sure your fridge doesn't have a recall for evaporator as is the case on my fridge I also thought it was electronic and first tech thought it was a leak in reality the evaporator was clogging and causing freon to not keep fridge cold or freezer to work properly but kitchen aid won't let you know you will have to let a tech look that info up for you.
Mar 15, 2014 | KitchenAid Refrigerators
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Water dispenser suddenly stop working
We have a Kitchen Aid that did the same thing. It could be that the reservoir tank is frozen or it could be that the line is frozen. We called Kitchen Aid, our fridge is under warranty, and they installed a freez kit over the tank and that solved the problem. The tank might be behind the vegetable trays on your fridge. What brand do you have?
Mar 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Kitchen aid bottom freezer dripping sound
drain cloged behind freezer panel?
Aug 26, 2009 | Refrigerators
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator makes lot of noise
based from your story. the noise could be coming from the compressor as it starts. compressor usually vibrates a lot when starting. it would last from a few seconds to a few minutes then would normalize as it sucked all the evaporator pressure down to its normal readings. you can check the rubber mountings of the compressor,you may need to replace them. also check for some tubings that may be rubbing or touching as the compressor vibrates. tighten alllso those mounting bolst of the compressor. that should solve your problem. if everything is done and still the same, the noise could be coming inside the compressor which there will be no solution but to replace the compressor. the cleaning that you did helped it a little bit because the vibration decreased a little coz it was able to breathe a little.
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
372 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
