I use the usb cable to upload my photo's, it's been working fine until recently, my pc no longer recognizes the camera, and when pluged in to the cam, the cam has no functions.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
You may have a bad USB in your camera connector in your camera. Any repair shop should be able to repair for less than $50.00. Also check that you do not have a bad cable. You may also want to try on a different computer than yours. if it works you may have a driver or USB conflict with your computer.
Make sure the camera is turned on, plug the USB cable into your PC first, then into the camera, wait for a beep from your PC to show it has recognized the hookup, then go to "My Computer" and look for the Fuji icon. Don't unplug the camera anytime the lights are flashing on it.
there may be problem with the pc suit installed with your pc.try to install again pc suit after uinstalling it.. if you have a card reader try with that.. hopr it works..
I tested it one more time at my home on my personal pc and it worked fine. Then when I came into work today, I pluged the USB cable into the second monitor and it worked. I have no idea why it would not work the other night. It's a mystery.
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
It's supposed to say that. When you plug it in, it says that, then once you are done uploading the photos and you eject the USB chord, those words will go away and you just turn off your camera and then turn it back on to take more photos.
