Question about Maytag Neptune MDG5500AW Gas Dryer
Not heating gas dryer runs but does not heat
  • 10 more comments
  • want2learn Jul 17, 2008
    Have the same problem what can be done, the drum rotates but not heat comes on some time ago the gas was turned off, later the valve was re-open but, I don't know how to light up the pilot, and don't know how to get to it...... if any of you guys can help.... will be greatly appreciated
  • Anonymous Jul 21, 2008
    my dryer runs but no heat is created. the gas is on, the temp is up and there are no clogs in the exhaust line
  • riley111 Jul 22, 2008
    My gas dryer runs fine, it just has no heat. I would guess it needs a new heating element. Can someone offer advice about how to replace it and what part I need?
  • spankydfb Aug 03, 2008
    My gas dryer runs fine, it just has no heat. Can someone offer advice about how to repare this unit?
  • Anonymous Aug 04, 2008
    ignitor turns orange but gas isn't released
  • Anonymous Aug 06, 2008
    igniter glows but the gas valve will not open
  • Anonymous Sep 10, 2008
    same as the rest. I took the vent off and ran it, and it still dose't dry the clothes in less than 4 hours.
  • cj9257 Nov 18, 2008
    i have a maytag (MDG9316AWW) that will not heat, ignitor is working, gas is on, same as everyone else but i have an additional problem, my timer does not move whatsoever, wherever i set and push start it will just continue forever until i have to manually go open the door, are these two issues related?
  • clb77581 Dec 13, 2008
    My Maytag MDG9316AWW gas dryer is not heating. I heard that a thermal fuse generally causes a dryer to stop heating. I don't know how to check the fuse or where it is located. I also noticed that the vent hose has a hole in it, and may have lint clogged around the hole. Will this prevent the dryer from heating? If not, can someone tell me how to check the fuse and where it is located? Thanks.
  • Anonymous Feb 23, 2009
    we have a 2 year old dryer and have the same problem, need info also!
  • FixMe911 Feb 28, 2009
    ditto here & still no help here!
  • jbeeman13 May 06, 2009
    i have same problem but how do oyu check the ignitor
I have a maytag gas dryer. I just had the motor replaced. Now, I don't have any heat. The gas valve is open. I have no clue why the heat isn't working
Posted on Sep 26, 2008
    Problem Solver:
  • 5 Answers
It may be this: They had a problem where the wax switch would go out and short out a resister on the motherboard. There was a recall on this but it has long since passed. You need to replace the wax switch in the door and the mother board.
Posted on Jul 25, 2008
  • rds95991 Jul 25, 2008
    Please disregard my previous post. Wrong appliance.
I'll tell you for a fee
Posted on Jul 14, 2008
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Replace the coils READ THIS!!!
Posted on Mar 14, 2009
Illeagle
  • 525 Answers
SOURCE: Maytag MDG4000BWW gas dryer does not heat up
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch. The links below are listed in order of failure commonality.
1.Gas Valve Coils
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3479&PartID=3479
2. Ignitor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3018&PartID=3018
3.Thermal Fuse
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di516650&PartID=516650
These are only the most common parts that tend to fail. There are numerous other components that could cause the same symptoms. If the above assistance does not resolve your issue, you may request assistance with an on-line technician, or you can order a service manual from www.repairclinic.com
Posted on Aug 30, 2009
  • 3230 Answers
SOURCE: my dryer runs but no
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Posted on Sep 22, 2010
Gas dryer won't heat up. It runs fine, but no heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Kenmore 74602 Gas Dryer
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Kenmore dryer, the dry runs, but does not heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
Runs but no heat
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
The dryer runs but will not heat up
heatman101
May 20, 2010 | Whirlpool GEW9250 Electric Dryer
LG DLG 2526W dryer running but no heat
heatman101
May 22, 2010 | LG D2526 Gas Dryer
My dryer runs, but doesn't heat up...
heatman101
May 19, 2010 | Whirlpool LER4634J Electric Dryer
63942 Dryer: runs air no heat , timer does not move...
heatman101
May 18, 2010 | Kenmore 63942 Dryer
Ignitor? dryer runs through cycles, but NO heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
gfgf
Oct 16, 2009 | GE DBL333GB Gas Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
538 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
