Question about Dishwashers
My Bosch SGV4313GB/12 will not finished its programme, it justs keeps on going. It doesnt finish program
3 Suggested Answers
  • 833 Answers
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Posted on Feb 11, 2008
The washing programm doesnt finish before it starts beeping
Dear Sir:
Reset the program, go to the next web page:
www. fitness.manualsonline. com give your model, etc, and download for free, sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 20, 2012 | Televison & Video
Bosch LogiXX - wont go beyond the prerinse stage to wash; keeps recalculating the time to finish.
Mine does the same, but i have a workaround: Use the standard program called "normal extra" from the submenu - does that work for you ?
Jan 19, 2011 | Bosch Dishwashers
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
check your filter. Could be an eratic pump. Dispening draw needs to be cleaned and make sure the small hole is clear to allow the conditioner to flow through
Feb 26, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Bosch exxcel programme runs until 1 min left and won't finish
This is a fault code which indicates it has not heated through the programme
Dec 13, 2008 | Bosch 24 in. SGS43C12 Classixx...
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Prgramme not starting or finishing
The "mushroom" bottom is just a lever that operate a switch. It seems that a part of the switch's mechanism is broken or release.
Jul 22, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
