I have a 5 year old Canon S750. The part which holds the ink tanks is not automatically going to the middle of the printer. When printer is turned on there's a slight grinding noise as tho the tanks would come to the center but they do not. The light blinks green & then 4 orange. What should I do??
    Genius:
  • 1,847 Answers
Did you try power cycle?
Posted on Jul 13, 2008
  • Legin Varghese
    Legin Varghese Jul 13, 2008
    Try these steps ....
    (1) Turn off the printer.
    (2) Press and hold the RESUME button, then press and hold the POWER button.
    (3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
    succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
    or move momentarily. If the above was properly performed the printer will enter the
    "Service Mode".
    (4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
    will alternate (change) color with each key press.
    1. Service/Factory test printout, including ink sensor check.
    2. EEPROM - Info printout.
    3. EEPROM - Initialization.
    4. Reset the Waste ink counter.
    5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
    After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Have a 1 year old Pro9000 thats starting to give
Use a Q-tip and a little water to wipe the wiper assembly on the right side of your machine. Unplug the printer when the carts are in the middle and look to the right with a flashlight. The wipers are supposed to wipe excess ink from the bottom of the printhead.
Jul 02, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
Canon ip 4500
This is the proceedure for older Canon printers, It may work for you.
Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
You are now in Service mode.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart. Just to be sure, unplug the printer power cord.
Plug the power back in and turn the printer on.
I have a S750 and I850 Canon printers and this works for me.
May 27, 2009 | Canon iP4500 Photo Printer
Canon S530D "Used ink tank is full" how do I remove the printer from the case to get at and clean the used ink tank? I need disassembly instructions.
The following may help, although the 530 is not mentioned
This resets, but not sure about cleaning the tank
Canon Printers S520, S750, S820, S900 and any S Series Reset Procedures
  1. Turn off the printer.
  2. Press and hold the RESUME button, then press and hold the POWER button.
  3. While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
  4. The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
  5. Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
    1. Service/factory test printout, including ink sensor check
  6. After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
May 05, 2009 | Canon Office Equipment & Supplies
The ink tank doesn't go to the middle
After you opened the front panel, did you lift the scanner section? The scanner section has a switch on it that activates the ink tank holders to come out to the middle so they can be changed. It is not the greatest design and it doesn't stay up by itself. I normally use an old cartridge to prop up the scanner section while I change cartridges. Hope this helps!
Apr 01, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
I have a Canon MP700 Printer. The message "waste tank nearly full" appeared. As I couldn't find any help in the manual I removed the ink cartridges to look for a "waste tank". ...
Dear miggsy,
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon Inkjet Printer Forum
Dec 05, 2008 | Canon Office Equipment & Supplies
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon model # S750 has stopped printing. The orange lite flashes 8 times indicating that the waste ink tank needs to be replaced. Is this something that I can do? If not, where do I go from here?
Your waste ink tank is full. the following will get you going again, but the sponges should also be cleaned or replaced, although I have not heard of any one having problems without doing this.
Canon S900, S820, S750, S520
Jul 02, 2008 | Office Equipment & Supplies
Canon F-80
I just fixed mine but I did 3 different things but my inks were empty...now that I replace the inks it works but not sure which one of the 3 fixed it so here they are
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
For printer model: Canon BJ F900, F890, F700, F500, S900, S820, S750 and S52:
3. Release the RESUME button, then press and release the RESUME button two more times in succession. (you?re still holding the POWER button during this). The printer mechanics will move momentarily.
4. You are now in Service mode.
1 times - Factory/Service test printout, including ink sensor check
2 times - EEPROM info printout
3 times - EEPROM initialization
4 times - Clear the waste-ink counter
5 times - Printer model setting. (more selections beyond this- leave this alone)
Nov 27, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Canon ink tank problems
I think I figured this B!tch out.
When you get the error:
"More than one ink tank of the following color is installed" or
"Ink cartridge not recognized"
Open up the lid where the cartridges are and hold done the "SEARCH" button. This has been working for me, and I bought my ip6600d in 2005, so my machine is old, and ready for this..........ORIGINAL INK!!! Never really used it beyond printing very few pics. So I was really pissed when I found these messages to almost 5 years after buying this printer. So to recap, open the lid where the ink cartridges are while holding the "SEARCH" button, hold it up for like 5 to 10 seconds, place lid down still holding the search button, then let go of the search button. I did notice the alarm was lit, but went away after I released the search button. Good Luck!!!
Until I held the search button down I had turned of the printer, reseeded the cartridges and open and closed the lid but it never worked.
Sep 19, 2007 | Canon Pixma iP6600D InkJet Photo Printer
k24674
