Question about HP Pavilion dv9000z Notebook
My plugin is broken
Oke so my battery works fine. the rest works perfectly. oke the heat is really bad.
but suddenly my hp stopt charging. i checked the battery and its fine.
now i see that my light of my power plugin is broke. meaning that if i have to keep it forced in with allot of power ore push it in a strange position it wont charge.
i wana know if this is a problem that happens allot. cause i think the its the jackin connection to the board that is broken ore lose.
hope that it is a easy fix cause i dont have that much of money and for it to be broken is strange cause its only been out of the house once in a year.
    Sergeant:
  • 457 Answers
My friend only u know what is going on.................if you think the battery is the problem then good but anything other than well you must be witness to it for instance the jackin connection how can u expect me to ascertain what your problem is when you know but is unsure............please???????
Posted on Jul 15, 2008
Jabra wave battery suddenly won't charge
The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
Jan 13, 2014 | Jabra Wave Bluetooth Headset
What are bad alternator symptoms?
If you happen to see the IGN light come on even after the engine runs or is intermittent specially when the headlights, AC and wipers are switched on , then there is low current on the alternator or the voltage regulator charging unit.
Also if you tend to think that the battery is not charging , has a difficulty in the morning then the voltage on the alternator output must be checked as the similar fault can be also due to a faulty charging control- rectifier or regulator.
Finally if you notice any burning smell or heating on the alternator it must be removed and checked on a test bench with simulation.
Sep 24, 2011 | 2005 Ford Expedition
All of the sudden it stopt working. Nothing happens when I push the ON button. I changed batteries. I took the backup battery out and put it back in (didn't put new one). Nothing helps. I changed the...
It is sold with an dapator that powers the calculator through the USB port. Use it and you will eliminate any doubt about the batteries. Try resetting the calculator.
Aug 26, 2011 | HP 50g Graphic Calculator
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
One fine day after low battery indication i plugin phone for recharge, it was well connected and showing charger plugin indicator on phone. phone was also working but percentage of battery was not...
You can try with this procedure, Try to charge another battery in this phone with another charger, if the battery got charged then there is an issue with your charger and battery, if it gives the same problem, then you have to get fixed your phone from repairing shop or your cellphone service center, it seems that the charging IC of your phone is not working properly which needs to be replaced, they will check the whole motherboard of your phone, and will fix the problem, if the set is in warranty claim it as soon as possible .
If you require more assistance, feel free to reply to this post
Thanks for contacting FixYA! Regards, BA
Feb 11, 2011 | Cell Phones
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
Will not start
bad silonoid on starter
the actual cable on starter is bad even though you replaced the positive battery connector the whole cable could be bad
also your new battery might not be a heat battery example= a battery that cannot handle heat and will die on you this indicates a dead cell in battery
bad alternator not charging battery
bad ignition coil
scorched spark plug wiring
dead cell in battery even though the battery can show good it can still be bad
battery's these days are usually refurbished battery's practically every one recycles batterys so its a chance that you got a bad battery try a jump then while vehicle running disconnect the positive post of battery if vehicle dies its the alternator
i myself had to do a battery swap 4 times before i got a refurbished battery without a dead cell this something that is a pain but once you get a good battery then everything should work
Jun 07, 2008 | 1996 Mitsubishi Galant
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Red Light
try to charge ur phone on other cradle if its getting charged then problem with the cradle or else try another battery in ur phone or contact service centre for more support good luck
Oct 11, 2007 | HP iPAQ hw6515 Pocket PC
HP Pavilion dv9000z Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
