Picture beginning to fail
Lately I've noticed that near the top of my screen, the picture is beginning to get distorted, about an inch vertically, and it goes all the way across the screen. The picture in this area bends heavily to the right, and is much brighter and more vibrant than the rest of the picture. I've also noticed that the picture outside the screen isn't quite as brilliant as is was before. When I turn the TV on, the top of the picture is actually about two to three inches from the actual top of the screen, and it slowly moves upward as it warm up, until it reaches the top of the TV where it should be, but it dips slightly in the middle. I'm really unhappy with this thing. I took a chance buying a Magnavox TV because I've always found their TVs to be lacking in many different areas. BUT I liked the sound setup, and it looked as though they have come a way since I last owned one, but alas I've been fooled. No Picture, Just a black screen. Does have sound. I've had since 1994, so it may not be worth the time or money to fix.
  • Anonymous Jul 28, 2008
    i have a sansui tv and the colour is green and purple
PITCURE IS GREEN AND PURPLE
Posted on Oct 25, 2008
I have an older Panasonic 26 inch tv the screen was a bit warped at the top off and on then the picture shrank to a bright horizontal line then went black the sound remains.
This is a common vertical circuit failure and if you had distortion at the top before,that was the capacitors in the circuit failing which filtwer the voltage to the vertical ic which has now failed as well.A lucky fix maybe just resolderingm the ic pins! A reputable shop may able to repair for less than $100 or I can guide you further to fix your self if you have technical expertise.
Jun 04, 2010 | Televison & Video
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Same Problem - Sony Trinitron picture dies out
You are probably dealing with loose solder connections in the horizontal and vertical deflection circuits. I am surprised it hasn't failed in a massive way yet. Too many times that is the way it ends unless those solder connections are taken care of.
Hope this helps,
Skyassoc
Jun 22, 2009 | Televison & Video
TOP OF PICTURE FLIPS DOWN VS-50605
try hitting the side of your set to see if you can get it to jump out of place. If your can get if to fail by doing this your convergence amps have bad solder joints.
Aug 29, 2008 | Mitsubishi VS-50607 50" Rear Projection...
There are some components it the vertical deflection amplifier area that are becoming thermo sensitive with age. It is also possible that there will be parts going off value in the power supply and other areas.
These problems are typical in these sets when they are aged. The cost of the repair may not be worth the investment.
You should take the set in to a service center for an estimate.
Jerry G.
Jun 12, 2008 | Philips Magnavox 20MS233S 20" TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Picture problem
Sounds like you are in the begining stages of vertical foldover. This is a problem where the vertical driver waveform is distorted due to a component failure causing the beam to not be driven all the way to the top of the screen. Usually there is enough overscan that you would not necessarily notice the picture being smaller than the crt. When this happens the horizontal scan lines, which have not decreased, are all displayed on top each other or as the condition worsens they invert. This causes the symptoms that you described. The solution I use is to replace all the electrolytic capacitors in the vertical drive circuit. There may only be one bad one but finding it will drive you nuts. They only cost dimes so we're not talking much money. Without a schematic you can usually be successful if you replace all the electrolytic caps around the vertical IC. If you are going to tackle this be careful. TVs are dangerous. Remember to unplug the set and discharge the crt High Voltage anode. Good luck.
Jun 20, 2006 | JVC AV-27D302 27" TV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
