Question about Epson Stylus Photo R2400 InkJet Printer
Feed and ink lights flashing
The Red lights flash alternatively and the green light goes off
  • 1 more comment
  • cato975 Aug 22, 2008
    I have exactly the same problem, flashing red lights every time I switch the printer on. No printing possible! Does anyone know of a solution for this problem?
  • philcrichton Sep 03, 2008
    same flashing lights and utilities tells me parts inside your printer are at the end of their service life?
  • pvsPhoto Dec 02, 2008
    My lights flash in unison, so maybe it's a bit different. I tried resetting with SSC v4.30, but that hasn't helped.
    Is there anything else I can try?
I have the same problem, but don't have the tool to repair. Could you please advise.
Posted on Nov 24, 2008
  • Epson Master
  • 541 Answers
Your printer need to be reset if you dont have the tool let me no and i will help you
Posted on Nov 17, 2008
Why the green light is off but the paper and ink red light flashing nonstop
Can not answer without more information. What brand of printer?
Are the paper/ink lights flashing alternately?
If your answers are, "Epson" and "yes, alternately", then the model number will help. Or, google "epson waste ink pad reset" for how to fix.
Aug 07, 2016 | Office Equipment & Supplies
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Red light keeps coming on and green one keeps flashing
is both light flashing alternately? if yes, it means you need to replace the waste ink pad and reset the waste ink counter...
May 20, 2010 | Epson Stylus C62 InkJet Printer
Alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Jun 26, 2009 | Epson Stylus Photo 900 InkJet Printer
Alternate flashing lights on epson stylus photo 900
Reset waste ink using SSC ver 4.3. Find at indoreset.blogspot.com.
Jun 26, 2009 | Epson RX620 All-In-One InkJet Photo...
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo R2400 InkJet Printer Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
