SOURCE: connecting Gateway HDMI TV to Playstaion 3
If your PS3 has HDMI capability and the monitor has HDMI capability, it should work as long as the monitor can match to the specs of the PS3.
I am not sure, but I think the PS3 required the capability of 1080p from the TV set. Make sure that your TV is able to see 1080p.
For HDTV, the standard A/V cable set is of no use. That is why your monitor probably does not support the standard A/V format.
Jerry G.
SOURCE: Linking a laptop to a HD telelvision
You may need to go into display properties in your operating system and activate the second display screen
SOURCE: Gateway nv52 won't turn on
I also had this problem. I turned it off and it would not turn on. I found the solution. First, extend the laptop screen as far back as it will go. Don't just stop the screen at a ninety degree angle. My laptop screen pulls back to about 135 degrees. Now press the power button. It should start up.
Why do I think this works? Well...I used to own an older model thinkpad that had a short "male" connector on the screen, that when the screen was folded down would enter into a "female" connector on the base of the unit and trigger sleep mode on the unit. This is how the system could automatically hibernate when the screen was closed. The little male connector broke off, and I couldn't get the system to wake up, because the connection to tell the laptop that I had the screen up or down no longer worked. I couldn't even power it up. I had to take an ink pen and push the connector through the female end to indicate to the motherboard that I'd opened the screen before it would even turn on.
It appears that the same type of mechanism is built into the long BAR under the screen of the NV52 and somehow it can't determine when the screen is open or closed. If it detects that the screen has not been opened, it won't power up. This safeguard prevents the laptop from being turned on mistakenly while closed up in your laptop bag. Extending the screen back resets the mechanism and it should turn on. Sorry for the long explanation...
SOURCE: Gateway DX4720-03 desktop the HDMI stopped working
Make your hdmi port a separate monitor in your display settings. If that didn't help leave a comment and ill try to help you again.
SOURCE: My husband broke my Gateway NV52 screen. It's
It maybe also your looking for the wrong screen, this laptop uses a LED not a LCD screen, hope this helps.
