My mitsibishi tv says its not getting enough ventelation and it shuts down. what can i do
    Genius:
  • 1,139 Answers
Hello bobtail0915,
This means that your set is not getting the proper amount of air flow in order to remove dissipated heat from the set. I would suggest moving the TV to an area with better air flow. Make sure that nothing obstructs the ventelation slots on the back of the TV set. This should help.
Thank you,
Shuttle83
Posted on Jul 13, 2008
We just replaced a DLP chip for a Mitsibishi TV. The TV does not turn on. We have not connected the screen yet. Any ideas what's wrong.
Be careful you placed all connectors in proper place, an make sure your ribbon cables are correct an matching pins. A common problem. Also you should put it all together because some power supplies shut down when everything not connected
Jul 20, 2017 | Televison & Video
Repairclinic.com
You have to check that the cooling system is working. Check the ventelator
Jul 09, 2013 | Computers & Internet
Mitsibishi VS-50703 will not power on. just here a click and shuts down
check from the ouput of the SMPS possible that the +B main is shorting., Use a multimeter to check on the main PCB only if you are familiar with poweer electronics. other wise just checkover for burnt components and replace if there is a shorted diode, transistor, capacitor or an open fusible. IF you systematically probe you might get to the problem provided you are aware of the stages and circuit.. hope my advise has helped ?
Jul 01, 2010 | Mitsubishi VS-50703 50" Rear Projection...
As switch power on the toshiba TLP791 projectorstatus of "on" and "lamp" light go to green to red after some time. Please assost us.
Does the unit light up? How mny hours are on the unit? most bulbs are rated for around 2000 hours some give warnings to clean the filters. Look in the menu and check the hours its been used.
Clean the filters, try and keep good ventelation to these because they get very hot and can overheat. They have sensors that will shut the unit down if they are overheating to avoid a fire.
Jun 09, 2010 | Toshiba TLP790 TLP791 PROJECTOR LAMP
Dryer starts to run for about a minute then shuts off, if you wait a little bit it will come on again but shuts off again
The motor is cutting out on over temperature. Either the motor is covered in lint: or the capacitor is faulty: or not enough ventelation comming in through the intake. If all is clear and clean, replace the motor.
Jun 05, 2010 | Maytag Dryers
Magnavox MDV630R1/17 DVD Recorder problem
Unlikely, but good possibility. Investing in a head cleaner would not be a bad idea. But also make sure the unit is well ventelated.
Dec 10, 2008 | Philips MDV630R DVD Recorder
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
