Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet: "remove the heater..."
In answer to the question "Sounds like there is a marble or coin in drum", you answered, "remove the heater which is held by 1 19mm nut in the centre", which sounds like it could help me solve a similar problem (dropped a screw between the drum and tub while installing new baffles)... Problem is, I don't know exactly where is the heater: could you point me to a source of documentation?
    President:
  • 1,462 Answers
Don't know the whirpool duet cos i'm in uk not us.
i assume your machine is a front loader
places to look for heater are
remove back plate and look for heater at bottom of rear face of tub
sometimes heater is mounted on front plate of tub in which case tilt machine backwards and see if you can see heater mounted towards bottom of front face.
most likely place however is on the rear plate of the tub
Posted on Jul 14, 2008
It sounds like Coins have found their way inside and tumble loud. Any way to get them out?
Yea ... but is it probably better to let them tumble until they work their way out of the drum.
You will have to take the machine apart and remove the drum to find the coins. Remove the bottom panel to get access to the screws that hold the upper front panel on. Remove it ... remove the drum. Take lots of pictures as you take it apart.
Like I said, it may be better to let them go.
Thanks for visiting today.
Jan 27, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Sounds like coins between the basket and drum. How do I remove the coins?
If it has baffles for washing, check to see if you can lightly press the baffle to one side (press firm but don't snap it out) while rotating the drum by hand. I do this with my Whirlpool Duet and the coins eventually just slide out and into the drum where I can see them.
Dec 06, 2010 | Maytag MAH8700A Front Load Washer
Whirlpool duet sport elec dryer. Gets warms then sounds like change rattling in the external drum area. During warranty said tech was a screw that kept coming loose to the drum causing the noise. 2 yrs...
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 10, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Model #WFW 8300 SW01 (noise in drum on high speed-sounds as if it has a chain or something inside rattling. How do we get a manual or parts book?
the rear tub.
and tub assembly.
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet washer. It sounds like
the rear tub.
and tub assembly.
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer sounds like a marble is loose
You washed something from your pockets. coins, marbles, I even removed a nail clipper before. Use a flashlight and try to look through the holes. If you can get front panel off. Put light under tub and see if you can see something that way.
Oct 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer sounds like marbles are in it when it spinns
look for an underwire bra wire it will be sticking in the drum
if you cant find it through the drum you may be able to reach whatever is causing the noise through the heater element opening in the tub
Feb 16, 2009 | Bosch WFMC 3200 Front Load Washer
Object blocking drum
quite easy to fix. take back panel off and remove heater - this is held by a 10mm nut in the centre. loosen nut and prize heater out and you can then see into the gap between tub and drum so you can fish marble out
Sep 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
remove the heater which is held by 1 19mm nut in the centre and prize out carefully with a screwdriver. you can then see the gap between the drum and the tub and fish out whatever is in there. a common problem
Jul 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
150 people viewed this question
Dan Webster
Dan Webster
Sal De
