JustAnswerhttps://www.justanswer.com > Electronics Question
Nov 26, 2018 - That error code very generally means that the signal input on the rear side of the VCR is not sensing any signal input. So the first thing to do ... 1 answer · Top answer: Hi, thank you for contacting JustAnswer.com. My name is***** will do my best to provide the ...
https://www.fixya.com > ... > magnavox dvd vcr e1
I'm trying to set up my new recorder It is displaying "E1" Hit the source button at the top of the remote to go to television, E1 is the input on the back of ...
Hi E1 is the display indicator the unit is looking for an External input signal or line mode E1 external input on rear E2 external input on front .,...No signal so unit turns off... change youre record channel, Cheers
The value of data read by E1 is faulty. [E1 reading is 7% or less (3.92V or more) or 19% or more (1.41V or less).]
C0F32, C0F33
Are PJ40, CN50, CN17, and PWBA PJ15A connected properly? Connect them properly.
Is the CN50 connection dirty? Clean
Is “C0F32” or “C0F33” displayed even when an I/C with the same T/ C as that of a new one has been installed? Change the I/C with a new one
Is “C0F32” or “C0F33” displayed even when an I/C with the same T/ C as that of a new one has been installed and an F8 operation run? (Be sure to record the ATDC control voltage setting value if an F8 operation is to be run.) YES Change PWB-A, install the old I/C, and return the ATDC control voltage setting to the value recorded. If “C0F32” or “C0F33” redisplayed, change the I/C with a new one.
is to be run.) NO Change the I/C with a new one.
The
less
Are PJ40, CN50, CN17, and PWBA PJ15A connected properly? (NO) Connect them properly.
Is the CN50 connection dirty?(YES)YES Clean.
Is “C0F32” or “C0F33” displayed even when an I/C with the same T/ C as that of a new one has been installed?(NO)Change the I/C with a new one.
Is “C0F32” or “C0F33” displayed even when an I/C with the same T/ C as that of a new one has been installed and an F8 operation run? (Be sure to record the ATDC control voltage setting value if an F8 operation is to be run.) (YES) Change PWB-A, install the old I/C, and return the ATDC control voltage setting to the value recorded. If “C0F32” or “C0F33” redisplayed, change the I/C with a new one. (NO) Change the I/C with a new one. if you are not tech pleas call your tech service.
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below. - E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.) - E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable). 2. Turn ON the main power switch. 3. Change the setting values of the following service mode items. - Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'. - Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'. Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1. - Color Image Reader-E1: Platen cover model - Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1) - Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180) 4. Turn OFF the main power switch, and connect the DDI cable. 5. Turn the main power switch ON. Note: How to turn OFF the main power switch. When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine. 1. Hold down the control panel switch for 3 sec or more. 2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.) 3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
That error is related to the laser unit. Check your connectors, they may have vibrated loose during move. These machines have a history of laser units going bad.
The source is E1, unless you are trying to display something froma camcorder or security cam. Philips does not provide enough cables with this product - they only provide you one set with which to PLAY a movie. You will need another red, white and yellow cable with which to RECORD. If you have a cable/satellite box, connect a 2nd red, white and yellow cord from cable box OUT to Philips AV IN. Switch the SOURCE on the Philips remote to E1, and your TV to whichever source you have the original red, white and yellow plugged into. You should get picture, and be able to record now.
