Question about Logitech Webcam
Bad video reception on the other end
I am told that people receiving my video say that it is like looking through a gauze sheet. The picture is very bad.
    Sergeant:
    Champion:
  • 417 Answers
Try turning the nozel on the web camera may be out of focus
Posted on Jul 16, 2008
Why does Bluetooth reception tend to skip and cut out randomly?
Hi
Usually the range of the Bluetooth transmission/reception is 10m max...
if you are transmitting above this rang it would do this interruption and noise.
another case.... it can be that the Bluetooth receiver is a bad quality.
hope this helps understanding the case.
Good luck
Dec 03, 2015 | Denon AVR-1100 Receiver
Cannot receive tv channels
if you are using a cable box tried to reset the box first let see if you can get channel. if you are just only using an areal antenna tried to make an adjustment in the antenna positioning which have poor reception then tried to look in other channel if you can receive local channel. if just only white raster like snow with no picture the cause could be the tuner get bad.
Nov 08, 2012 | Proview PA-32JK1A 32 in. LCD Television
Bad fm reception
This is probably due to the area your FM antenna is placed. If your house/office is surrounded by buildings, the signal will weaken and fade before it reaches the antenna. Also, if it is surrounded by many walls(i.e. deep inside an office complex), you will have bad reception.
Nov 02, 2012 | Sony STR-DE197 Receiver
Our Konica Minolta BIZ HUB C10 message in window is MEM.RX. Can you explain what this means. Thanks
In the Fax/E-mail - Fax Configuration - Reception Operation page, set-
tings for receiving faxes can be specified.Memory RX Mode:
Select whether to allow ("On") memory reception or not
("Off"). In cases when confidential faxes are being
received, the received document can be stored in the
memory and printed at a specified time or when memory
reception is set to "Off". A password can be set to spec-
ify the starting time or ending time of memory reception,
or to cancel the function. The set starting time and end-
ing time are valid every day until memory reception is
turned off.
Choices: On, Off
Default: Off
Configuration Menu Equivalent:
RX SETTING - MEMORY RX MODE
Mar 27, 2011 | Konica Office Equipment & Supplies
The FM antenna is insufficient. I there a way to improve reception? Another antenna that will fit?
To improve reception, use a 75 Ohm outdoor antenna instead of an indoor antenna. Disconnect the indoor antenna before replacing it with an outdoor antenna.
Dec 14, 2010 | Insignia 200W Stereo Receiver
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Grainy picture
Hi and welcome to FixYa,
Initially, some ideas you may want to try/consider:
  • other than the TV, all switched off and unplug. Try evaluating the reception of any/all TV channels;
  • if quality is bad, either the tuner (least likely) is bad or a problem with your cable system/provider;
  • if the quality is good, then either the DVD or the game console has an RF modulator that interferes with the Toshiba's reception;
  • if the grainy picture is when using the Audio/Video inputs, then it would not be the tuner but rather the video processor;
  • should the tuner really require replacement, it would be relatively easy since it is a single block/assembly with a couple of pins and a mini coaxial connector;
  • best approach would be to reference a Service Manual. Pls bear in mind that voltage check requires the unit to be powered on and therefore exposes you to potential electrical hazard.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Toshiba 57HDX82 57" Rear Projection HDTV
Composite a/v and s-video picure look like hell.
I want my computer photo to see it on cd/dvd players
Jan 12, 2009 | Yamaha RX-V663 Receiver
Electrolux vacuum turning off
hi take off canister cover remove bag now if you look inside canister you will/should see a gauze type filter at the opposite end of canister from where bag locks in ?? remove this gauze filter and for now just shake tap on floor to remve dust/debri etc /from it this gauze is the filter that when vac is working andfilling the dust bag ? the pressure of air only that blows bag up but allows only air to pass thro the microscopic holes in bag ? then has to expel via the gauze filter to exterior ? and any dust etc that is clever enough to seep through the bag ??? will not pass further due to gauze ? and so prevents this blowing back into room ok so far ?? if this gauze is blocked due to whatever ?? then pressure build up in canister will result in cover lifting? this is provided that the fault is not the actual cover securing latch is ok and not damaged ? hope this explains and helps ? best wishes from uk !
Nov 08, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
