Question about Sony KP-48S35 48" Rear Projection Television
Sony KP-48S35 Picture
Picture is "bowed in" on all 4 sides.
  • 1 more comment
  • gast9406 Jul 13, 2008
    The picture on my Sony KP-48S35 rear projection TV is ''bowed on all 4 sides when I first turn it on and then corrects after about 10 minutes of playing. Is something about to go bad on it?
  • gast9406 Jul 20, 2008
    Thank you for your answer. I'm pretty sure you're right about the failing solder joint because when I pulled the unit away from the wall, it corrected itself. I then was able to bump it on the side and it would correct. Now, however, that doesn't work any longer. Would you please give some advice as to where this circuit is and as you said, thhe most likely capasitors? Any assistance you can give will be greatly appreciated. Thanks again.
    gast9406
  • gast9406 Jul 26, 2008
    Well, I looked where you told me to look and found exactly what you predicted I would find...a bad solder joint on a resistor. I reflowed the solder and the picture has never been better. You guys are either genius or psychic. Thank you very much. I'm sure you saved me hundreds of dollars on a repair or a new TV. You are truly a guru.
    Gary
    Problem Solver:
I repaired a bad solder joint on a resistor near one of the IC STK392-XXX. It was exactly as you suggested it would be. Thank you very much. You are truly a guru.
Posted on Jul 26, 2008
    Scholar:
  • 135 Answers
Dear customer
It MIGHT be something you can adjust, but probably NOT. If you own a Sony there is a small hole on the back panel, with a tiny push-button switch within, then your set has a remote service mode.
If you press and hold the button, then turn on the set, it will come up in service mode. " ...
... Did you try UNplugging the set for 2-3 minutes? That might de-magnitize the tube. Make sure there are NO motors or electrical stuff around the set.
The 'expert' site says: "...The pincushion effect you saw worries me, too. But it is too unlikely the convergence board is gone as well. You can get a pincushion effect when the high voltage dies down, but you should also have seen the image on the screen become dim due to lack of accelerating voltage. So, I am going to stick with my prediction that the problem is in the main power supply section that is feeding the deflection amplifiers. Further, I am going to predict it to be an electrolytic filter capacitor that has shorted down the B+ line..." etc
U have to change the convergence board.
thank u
Posted on Jul 14, 2008
  • 2,307 Answers
I would suggest to try to locate the ICs STK392-XXX and inspect the solder joints for crystallized conditions using a 2X or 4X magnification aid. Also you should check the resistors nearby the ICs for the same condition.
Let me know if you need further assistance.
  • 4,234 Answers
Since this recovers on its own, there are a few possibilities:
1) There are bad connections on the board that self-correct as the unit heats up a bit.
2) There are capacitors in the convergence and pincushion circuits that are starting to fail.
If you can solder, you can repair this yourself. First look for poor solder connections that appear to be grainy or have rings and resolder them. If that fails to resolve the problem, we next have to look for failing capacitors. I will look up the most probable caps in both circuits and post the circuit designations here.
Keep up posted on your progress.
Dan
  • ABRsvcs Jul 21, 2008
    I don't know hte layout of the board inside your model, so I can;t direct you to the specific point to resolder. But... Look at all of the solder joints on the board and resolder any of them that appear to be grainy or have rings. Usually when a joint goes bad, it develops a ring that looks like a circular crack.
    Keep us posted.
    Dan
Sony KP 48s35 Has great sound but no picture.
red picture tube might have shorted to the point where it pulls too much current not letting set come on. J.D.W.
Jun 24, 2010 | Sony KP-48S35 48" Rear Projection...
Sony kp-61s70 hour glass shape on picture bows in
the sony service menu can be entered by pressing "display" "5" "vol+" also the diagnostic screen can be reached by vol- instead of + when you are in the service menu the number buttons navigate it its a little tricky at first but as long as you dont hit enter before you exit if you mess up it wont save just make sure if you fix it you save it by pressing enter
Jul 13, 2009 | Sony KP-61S70 61" Rear Projection...
I have a pic problem is it fixable
If the picture is bowing in on the sides, this is called a pincushion problem. Please confirm that your model is KP-53XBR45 and I'll look up the probable defective parts.
Dan
Aug 26, 2008 | Sony KP-53XBR45 53" Rear Projection...
Sony kp-48s35 projection
STKs can also shut set off BIG black ics,also check pico fuses.
Jun 13, 2008 | Sony KP-48S35 48" Rear Projection...
Sony kp-53s10
Hi: Check the horizontal output stage. Many Sony chassis have a control scr device on the emitter of the h.o.t. or the flyback may be bad. Good luck.
Jan 29, 2008 | Sony KP-53HS10 TV
Sony kp 48s35 front screen broken
http://www.partstore.com/Part/Sony/Sony/KP48S35/Sony/Sony/408470101/New.aspx
this is the link for the fresnel screen but i myself am trying to find the lenticular screen but so far no luck
Oct 15, 2007 | Sony KP-48S35 48" Rear Projection...
Sony KP-48S35 48/Broken Screen
The fresnel screen and the lenticular screen. The fresnel is part # 405845511 and is about $160 new. The lenticular is # 405845411 and is about $330.
Milford CT Real Estate
Oct 12, 2007 | Sony KP-48S35 48" Rear Projection...
Kp 48s35
This is not for the protective screen this part # is for the fresnel screen part # 405845511
Try: http://parts.com
Oct 11, 2007 | Sony KP-48S35 48" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
