Question about Frigidaire CWS3600AS Top Load Washer
Washer won't drain
Hi! My washing machine won't drain. I tried removing the tube from the wall and placing the end tip under the level of the tip that originate from the machine. The water was then drained. So the problem seems to be that the water is not being pushed up through the pump high enough to drain in the whole dedicated to it.
Any ideas?? Thanks.
    Scholar:
  • 148 Answers
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
please rate this solution thanks
Posted on Jul 13, 2008
Kenmore Elite HE 4t front load washing machine leaking water bottom right bottom at the end of wash
Unplug the power cord from the electrical outlet. Pull the machine far enough from the wall to get behind it to work
Use a putty knife to pry up and remove the end caps from the control panel. Remove the retaining screws from the control panel with a Phillips screwdriver.
Lift the control panel, and push it toward the back of the appliance. Unplug the wiring harness from the control panel. Remove the retaining clips using a flat-tip screwdriver to release them from the cabinet. Tilt the cabinet of the washer away from the frame, and set it aside.
Remove the pump retaining clips using a flat-tip screwdriver. Pull the pump from the motor shaft. Release the hose clamps using a pair of pliers, and pull the hoses from the drain pump.
Connect the hoses to the new drain pump using a pair of pliers. Place the pump on the motor shaft, and secure it with the retaining clips.
Set the cabinet in place on the washing machine frame, and install the retaining clips with the flat-tip screwdriver. Plug the wiring harness into the control panel. Close the control panel by pulling it forward, and install the retaining screws using a Phillips screwdriver. Install the end caps on the control panel, and push firmly to lock them into place.
Plug the power cord into the electrical outlet. Push the washing machine into place against the wall.
Custom Car Parts
Jun 06, 2012 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Water comes into machine but it does not spin.
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Good luck...
Apr 14, 2011 | Kenmore Washing Machines
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Why the fan is not working , the fan not move
1.Check to see if the washer is overloaded. Modern washing machines have automatic shut-off devices for out-of-balance loads. Try removing some of the clothes out of the washer and restart it. Check to make sure the lid closes properly and that the lid switch clicks when the lid is closed. If the lid switch does not click, then the switch may need to be replaced or the lid may be bent. If the washing machine still does not spin, go to Step 2. Make sure the water is draining properly. If the water does not drain out, then it could cause the washing machine not to spin. Check all the drain hoses for any clogs or kinks. This is easily done by disconnecting the drain hoses and doing a visual check for clogs or kinks
3.Check to see if any belts have came off or are loose. Unplug the washer and pull it away from the wall. Use the screwdrivers to remove the back panel. Visually check for any broken or loose belts. Replace any loose or broken belts.
4. While the back panel is off, visually check for any loose or missing bolts on the motor or drum. If any are missing or loose, tighten them and replace the ones that are missing.
5. If everything has checked out to this point, then the water level switch could be bad or the water level hose could be clogged. Remove the front panel of the washer and locate the clear tube going from the tub to the water level switch. If lint or debris has gotten into the water level hose, then the washer may not spin fast. Clean the debris from the hose by blowing on the hose or tapping it on the side. To check the water level switch, go to the back of the washer and locate the back end of the water level hose. Use the voltmeter to check to see if the water level switch is getting any power.
6.If the washing machine still doesn't spin fast enough or doesn't spin at all, then it is time to call in a professional washing machine repairman.
  • 1
    Checkto see if the washer is overloaded. Modern washing machines haveautomatic shut-off devices for out-of-balance loads. Try removing someof the clothes out of the washer and restart it. Check to make sure thelid closes properly and that the lid switch clicks when the lid isclosed. If the lid switch does not click, then the switch may need tobe replaced or the lid may be bent. If the washing machine still doesnot spin, go to Step 2.
  • 2
    Makesure the water is draining properly. If the water does not drain out,then it could cause the washing machine not to spin. Check all thedrain hoses for any clogs or kinks. This is easily done bydisconnecting the drain hoses and doing a visual check for clogs orkinks
  • 3
    Checkto see if any belts have came off or are loose. Unplug the washer andpull it away from the wall. Use the screwdrivers to remove the backpanel. Visually check for any broken or loose belts. Replace any looseor broken belts.
  • 4
    Whilethe back panel is off, visually check for any loose or missing bolts onthe motor or drum. If any are missing or loose, tighten them andreplace the ones that are missing.
  • 5
    Ifeverything has checked out to this point, then the water level switchcould be bad or the water level hose could be clogged. Remove the frontpanel of the washer and locate the clear tube going from the tub to thewater level switch. If lint or debris has gotten into the water levelhose, then the washer may not spin fast. Clean the debris from the hoseby blowing on the hose or tapping it on the side. To check the waterlevel switch, go to the back of the washer and locate the back end ofthe water level hose. Use the voltmeter to check to see if the waterlevel switch is getting any power.
  • 6
    Ifthe washing machine still doesn't spin fast enough or doesn't spin atall, then it is time to call in a professional washing machinerepairman.
  • Read more: How to Repair a Washing Machine That is Not Spinning Fast Enough ' eHow.com http://www.ehow.com/how_5025687_repair-not-spinning-fast-enough.html#ixzz1CKKbvlyA
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
    Jan 28, 2011 | Magic Chef CAV2000 Top Load Washer
    Washer wont run or drain
    hi friend,
    step 1
    Check to make sure that the lid locks properly upon closing. You can do this by closing the lid and listening for an audible "click." If you don't hear one, you may need to replace the latch.
  • Step 2 Pull the washing machine out from the wall.
  • Step 3 Remove the draining pipe that runs from the back of the washing machine and into your drain by unscrewing the square panel that holds it in place.
  • Step 4 Tip the drainage pipe into a bucket. If nothing comes out, you have a blockage.
  • Step 5 Push an unbent clothes hanger into the tube. Try to force any obstruction through the pipe, or try and hook it and pull it out. It is most likely a small item of clothing, a hairpin or some other small obstruction.
  • Step 6 Drain the tube into the bucket when you've removed the blockage.
  • Step 7 Screw the panel back onto the back of the washing machine.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If this method does not clear your washing machine, call a professional repairman. Any repairs past the drainage tube are best left to a professional.
    hope this helps u
    please rate me...................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | GE Profile WPXH214F
    Washer wont drain
    HI, Does the motor run while in the drain cycle? With the wjater out of the washer, tip it back against the wall and see if the belt is ok. You can also remove the belt and try turning the pulley on the pump (located in the rear right corner) with your hand
    If the belt is on and the motor runs, the pump is probably going bad.
    Please let me know if I can assist you further.
    Thanks
    Vic
    May 24, 2009 | Amana 3.2 cu. ft. Top-Load Washer
    Washer fills up than starts draining while in wash cycle
    Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
    Phil
    Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
    Water wont drain from Machine or go onto spin cycle
    either the level control switch has become blocked or faulty or the drain pump has become stuck.
    disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
    Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
    Washer won't stop filling with water.
    slick, first see if the hose came off the pressure switch. Just grab the end caps on each end of the control panel and pull them off, they snap on. Remove the two consol screws, pull foward and flip the consol up. See if the hose came off. If it did, just put it back on and use a zip tie to secure it. See attached photo. Catriver...post back.
    Mar 18, 2007 | Kenmore 22642 Top Load Washer
    Frigidaire CWS3600AS Top Load Washer Logo
    51 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    prem mathew
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
