Question about GE Kitchen Ranges
My front panel displays LOC ON no matter what button I push. Therefore, I can't turn on my oven or use my timer. What to do.
Unplug the oven, open the panel (by removing the 2 screws) above the lock handle. Clean it out. Sometimes mice can get in there and move insulation, etc. and if anything gets in between the lever and the micro switch it will make the oven think that it is locked. If it is clean, push the lever back and forth and listen for a clicking noise. If it doesn't click you need a new micro switch. I just had a similar problem and Tom at quality@applianceeducator.com helped me fix mine. Hope this helps you!
Posted on Jul 13, 2008
CONTROL PANEL FOR OVEN NOT WORKING AT ALL
Hi - I understand that the burners work, however I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed, confirm that there isn't a wiring failure or a faulty element.
Oct 17, 2012 | Frigidaire FEF366 Electric Kitchen Range
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
The loc on light comes on when i push any button on my stove i do not know how to get it off
The LOC light indicates the front panel lock is on. This keeps you from starting the oven when cleaning the panel; it also keeps children from turning on the oven. To disable the lock, press and hold Bake and Broil Hi/Lo together for 2+ seconds until SF appears on the display. Then press Self Clean. Then press Start to exit the Special Functions menu.
GE appliance manuals are available from their site. Go to http://www.geappliances.com/service_and_support/literature/ and enter the model number of the appliance. Then click Search.
I hope this helps.
Jun 26, 2011 | GE Profile JTP18 Electric Single Oven
I have a new control panel that was just put in 2 weeks ago. I pressed the button start to long & the "Loc" came up on the display & it won't go off no matter what button I push. I've...
Did you replace the panel yourself? If it was a repairman it should be under warranty. Anyway I would think that after the supply has been turned off overnight the timer would reset itself. If that doesn't work and you don't want to keep mucking around with control panels and you can do without the electronic clock the control panel can be easily bypassed by a repairman. This will then enable manual oven operation.
Feb 16, 2011 | Ovens
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
    Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
    Range - "LOC DOOR" flashes in the display
    If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
    Motorized Switch
      1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
      2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
      3. While you hold the door jamb switch in this position, complete the following steps.
      4. Press the Clean pad, wait 10 seconds.
      5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
      6. Wait 10 seconds for the display to clear.
      7. The door should unlock and there should not be a need for service.
    Manual Switch
      1. Press the Clean pad.
      2. Close the door.
      3. Slide the latch to lock the door.
      4. Hit the cancel button immediately.
      5. Unlock the door.
    Motorized Switch
    Manual Switch
      2. Close the door.
      5. Unlock the door.
    Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
    Oven Door panel is showing LOC position but can be opened and closed so not locked. Unable to use oven for cooking
    What is the exact make and model of your oven? Unplug the power cord for one hour to reset the display
    Mar 18, 2010 | Kitchen Ranges
    Mwk100x7 kleenmaid microwave displays in lcd panel 'LOC'
    I did solve the problem myself after leaving the microwave alone for 20 minutes after which it reverted to the normal functions. Many thanks for your interest. Kind regards, Ash
    Oct 04, 2009 | Microwave Ovens
    Display says LOC,
    I have a whirlpool range and I'm trying to get my display off of lock. I reset timer wrong and now nothing works.
    Feb 03, 2008 | Kitchen Ranges
    "loc" display
    This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
    Dec 08, 2007 | Whirlpool Ovens
    Kitchen Ranges Logo
    65 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
