FixYa.com
Tags:
D-Link AirPlus DI-524 Wireless Router
Router not being recongized
posted by Madhavi Ram on Jul 13, 2008
Router is not recognized.
The status and the WLAN lights are static and do not blink.
Tried unplugging, powering off and resetting the ip but still doesnt work. I can connect to internet when directly plugged into the port.
Tried different ethernet cords..still not luck
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 14, 2008
Not Rated (0)
AlmostBob
Rank:Guru Guru
Rating: 85%, 140 votes
Assumption Tried different ethernet cords,
WLan only blinks when accessing wirelessly, cables imply cable connection, or is this the cable connection between the router and modem.
Routers do NOT require software installed on the pc.
Connect the original pc that worked before the router was installed, by ethernet cable to lan1 port on the router.
type the address http://192.168.0.1 into your choice of browser to open the web interface on the router.
use the wizards of the router web interface to configure the wireless connections, record all settings and transfer to the pcs that should connect wirelessly. the helpscreens are very good and will explain what you are setting
do not install software to drive router to pc
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 13, 2008
Not Rated (0)
280zlvr
Rank:Guru Guru
Rating: 89%, 43 votes
if your running windows xp then you should remove any programs that you installed to run router then look into hardware manager and uninstall router and restart computer . then try once again plug in router once comp boots and let win xp load the correct drivers if this doesnt work go to windows update website and get all available updates including all hardware updated then try installing again good luck with it
Can you Help with these Routers problems?
Routers
PS3 ONLINE TROUBLE
i have a ps3 but it wont let me... Answer This...
DI-524 router problem
when the D-Link is hooked up to... Answer This...
Routers
Fritz!BOX fon WLAN 7170
Hallo, ich habe diese Box... Answer This...
Routers
hurricane h5200 modem/router
i tried portforwarding using... Answer This...
Routers
hhjjj
i have a problem with sitecom... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
