Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
I just bought a DW735 planer and ran a 6" x 24" piece of 3/4" poplar through it, with the planer set to remove 1/16" of thickness. I used the speed 1 (slow). It ran through fine, but I got several irregularly spaced ridges about 1/64" to 1/32" wide that ran the length of the board. The ridges are about 1/64" high, protruding up from the main reduced thickness of the board. The same thing happened over and over again. Is this normal? Do I have to return the machine for a blade change? I have not taken the machine apart to inspect the blades.
    Champion:
  • 313 Answers
Where is the ridges happened at the begining of the board or at the end of the board. if its the middle of the board the problem is the roller sleeve may be worn.secondly the roller may have lots of sap from the wood/varsol can do job for cleaning the roller. 3. is the balde. see www.toolpartsdirect.com for the parts diagram,in large the picture
Posted on Jul 13, 2008
My dewalt planer dw735 just made a loud pop sound. Then, a piece of metal launched out of the dust ejector, a few sparks flew. I tool the top od and found a hunk of wood that broke of the board jamming the...
have you checked you have not taken a chunk out your blade. also you have to make sure the blades are set spot on. other wise it will affect the balance. good kuck
Dec 20, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Replace v belt on dw735 planer
REMOVE COVER SO YOU CAN SEE THE BELT, PULL THE BELT AS YOU TURN IT AND IT SHOULD COME OFF
Nov 07, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Dewalt dw735
If its been used a lot the brushes may be bad
Jan 03, 2014 | Garden
Dw735 planner thickness
Is it cold in your shop? The rollers won't work if they're cold because the rubber gets stiff. Clean your rollers also with mineral spirits. Hope that helps.
Jul 11, 2013 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
HOW DO YOU REMOVE IT FROM THE TABLE?
Al ,How is it attached to the table? My Dw735 is screwed to the table ,so for transport I simple remove the screws.
Apr 30, 2012 | Dewalt 13 in Planer
Can I get a paper manual for the 735 planer?
Got to:
www.servicenet.com.
You can order a replacement manual for the dw735 from them.
Hope this helps.
Apr 23, 2011 | Dewalt 13 in Planer
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
135 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
