Question about GE Profile Spectra JGBP79 Gas Kitchen Range
Hi...need help with my oven it won't heat up
Hi Mr. Bean-
Any help would be appreciated...GE profile model #JGBP79AEV1AA. The oven is not working properly. The broiler works, the pilots on the stovetop work fine but when I turn on the oven the digital display stays at 100 degrees and generates no heat. I took out the sliding storage bin underneath to see if there is any light but I see nothing. I'm not sure if it is behind a panel or it is not on....please help. Any advice is deeply appreciated.
I would love to be able to fix this myself without blowing up the family. If I am in over my head let me know and I will go oven shopping. Thanks....
Hi Mr. Bean,
Is this apply to the GE 24" gas wall oven as well? Thanks.
Posted on Jul 28, 2008
  • 5,911 Answers
If your surface burners work and the broiler operates normally, more than likely you have a failed igniter on your bake manifold. There are two separate igniters on your oven. One is for bake, and one is for broil. This is a common failure, due to the fact that the bake function gets used more often than broil. I found your part listed at repairclinic.com. Just type in your model number and the igniter is listed as item number 1990. For instructions on how to replace the igniter, click on the following link:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Just make sure you turn off the gas and unplug the range before starting any repairs. If you require further assistance, please let me know. I hope this information is helpful to you.
Posted on Jul 13, 2008
Broiler is working but oven ignition not lighting pilot
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
67iutr
Sep 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    The oven doesn't come on-but the self clean and broiler work
    Check the electronic starter/pilot ignition on the bottom oven burner. It may be dirty, too far away from the pilot gas or the temp sensor on the pilot light flame may need replacing.
    Dec 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    I have a ge xL44 and I can't get the oven or broiler on...How do I get the pilot to light?
    heatman101
    Dec 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Stove, stove top works but the oven will not heat up.
    You will most likely have to replace the oven igniter. If you have the model number you posted under, I believe the igniter for the broiler is the same as the oven broiler, and could be swapped out to get the oven working again. (of course, now the broiler won't work until that igniter is replaced) If you'd like the part number or any further advise, comment back with the full model number off the sticker just behind the lower drawer panel on the frame of the range. Tonight, you may have to finish the chicken on the stove top.
    Mar 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    The oven broiler work but the baking part doesent.
    hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
    Sep 30, 2008 | GE JGRP17 Gas Single Oven
    GE Spectra oven not lighting
    you need a new oven ignitor for bake if its a gas stove..
    May 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JGBP79 Gas Kitchen Range Logo
    239 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
