Is it set to run disc or hard drive 1st?
if reinstalling windows it needs to boot up from cd drive 1st and this will automatic copy to new garden drive, after that change bios to boot up from hard drive.
In order to be detected the hard disk drive by your windows xp installer. You have to set your sata in your cmos or bios setup. When powering your computer tap the F2 key or Del to enter cmos or bios setup, go to integrated peripherals and look for the sata controllers. Most of the times if its configured as a enhanced the windows xp can not detect it. You have to change the settings to compatible mode. Please the modify key either F5 or F6 or PGUP/PGDOWN or + or - . After changing the settings press F10 and press y and enter. Then try again running the windows setup. Have a nice day.
Check in your BIOS,first make sure the SATA controller is set to native mode and not RAID, and secondly that the BIOS can detect the drive, if the drive can't be detected by the BIOS then it's because the drive surpasses the boards drive size limitation.; If this is the case there is a chance a BIOS update may fix it but it's not guaranteed it will.
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Goto bios menu. And change the setting on hard drive and cdrom. It could be it still set in the old configuration. Try to set it in auto detect. Then save the setting. Then goto bios once again to check if the settings doesn't change. Restart again and wait if something you didn't expect still happens.
IN THE BIOS SETTINGS LOOK AT THE HARDDRIVE SETTINGS THIS SHOULD BE WHERE THE PROBLOM NEWER LAPTOPS HAVE THIS BIOS SETTING THAT PREVENT XP INSTALATIONS. I REMENBER FIXING A SIMILAR PROBLEM. GOOD LUCK !
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
