FixYa.com
Tags:
HP OfficeJet 6110 All-In-One InkJet Printer
Grinding noise (by 6 users)
posted by cin22homeo on Jul 13, 2008
My power failed and now when I try to turn on the printer I get this grinnding noise that won't stop and it will not respond to any commands and tells me to turn power off. What do you think it could be???? Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on Jul 28, 2008
SAME PROBLEM
Comment by Guest, posted on Jul 23, 2008
I have the same problem - it always happens after power failure
Comment by balou, posted on Jul 22, 2008
i have the same problem
Comment by c11thtee, posted on Jul 19, 2008
I have same problem!. Any cure anyone?
Comment by Guest, posted on Jul 19, 2008
my hp printer has the same problem like yours. When you turn power on the printer goes to the initializing mode. The scanner light is turned on and move out from the resting position about an inch or so and goes back to the resting position. At this time, the motor that drives the belt to move the light should be off but it keep running. That's why we hear the grinding noise. I'm still searching for the solution. I think the motor misses the mark that tells it to stop.
Best Solution
FixYa! (100)
furtzel
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
I have the same problem - always after power failure - can anyone help?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 29, 2008
Not Rated (0)
cuzisayso2
Rating: 0%, 0 votes
Same Problem here too :(
Solution #3
Not Rated (0)
c11thtee
Rating: 0%, 0 votes
I have same problem
Can you Help with these Printers problems?
Won't print anything
I replaced the ink on my 6110... Answer This...
fax
i can receive faxes but when i... Answer This...
HP 6100 All in One malfuntins...
I recently moved this machine... Answer This...
Black ink not printing
I put in a new cartridge. It... Answer This...
HP Officejet 6100 All in one.
pnt from PC, 1st pg give paper... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
