Question about Nikon D50 Digital Camera
Camera not working
The camera is not releasing the shutter....the battery icon on the LCD blinks..while the counter is on registering anything....please help
  • Tim Babcock
    Tim Babcock May 11, 2010
    If the battery icon is on doesn't that mean the battery needs to be replaced?
    Problem Solver:
  • 3 Answers
Posted on Jul 22, 2008
I hve transfered all the photos from my Hero 16 MG disk to my PC. it is still not allowing me to take new photos and videos just indicating "Full"Unclear how to erase my disk. Any assistance you could
Here are the steps to reformat your SD card with your HERO3 camera:
  1. Power ON your camera with the SD card inserted.
  2. Press the front (Power) button repeatedly until you see the wrench icon on the camera's screen.
  3. Press the top (Shutter) button one time.
  4. Press the Power button repeatedly until you see a trashcan icon.
  5. Press the Shutter button one time to select the trashcan icon.
  6. Press the Power button until "ALL/Format" is highlighted.
  7. Press the Shutter button one time to select "ALL/Format".
  8. Press the Power button until "Yes" is highlighted.
  9. Press the Shutter button one time to select "Yes". Your camera's LED and the trashcan icon will blink to indicate that your SD card is being reformatted.
Once they stop blinking, power OFF/ON your camera, and your file counter should show 00.
Important - Take a picture. This confirms that your SD card is successfully reformatted.
Sep 19, 2014 | GoPro HERO3 White Edition Action Camera
This is an old nikon camera FG. I have put a new battery into the camera and set to what the manual tells me to do. But looking through the viewfinder when I depress the shutter release button non of the...
Hi, see if the batteries or the battery are installed correctly (positive side as the bat. cover shows + sign).
Mesure the voltage = 3 volts.
Look at the battery cover and body contact, and see if there is contact battery leakage;clean if necessary.
Also the counter should be in 1, nothing happens, the counter SW dirty or defective contact.
Other Main PCB bad.
Best reggards
Feb 23, 2011 | Nikon Cameras
How do set the self timer in Nikon F70
Press the SET/timer button (top left of the camera, behind the FUNCTION button, marked SET with a one-handed clock icon) and confirm that the one-handed clock begins blinking on the LCD panel. While pressing the SET/timer button, rotate the command dial one click to stop it blinking. Proceed normally (frame and compose picture, half-press shutter release button to meter and autofocus, etc). Fully depress the shutter release button to take the picture after a ten-second delay.
If you need a manual, you can download one from http://www.butkus.org/chinon/nikon.htm . Look for "N70", which was the name used in the USA.
Apr 29, 2010 | Nikon Photography
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
Shutter release button wont work! Help please, and fast.
skye-skye,
is the light meter working ? if not replace the batteries
Nov 16, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
I have a sony SLR camera-model DSLR-A300k. The camera shake icon is flashing and the camera will not function. It is turned on and I can see the image on liveview on the LCD screen but cannot use the...
I just took mine to the camera store and the woman at the counter swapped out my lens. The camera now works and the camera shake icon is gone. Try changing the lens, this worked for me and I had the same problem.
Jul 23, 2008 | Sony Alpha DSLR-A100 Digital Camera
D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Feb 03, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
66 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
