Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
RAYMARINE First of all, hubby is electronically challenged, our boat is equipped with hi-tech Raymarine. We noticed yesterday, the marking of our boat on the screen, identifying where we are, has disappeared. Also, our depth finder works now and then. I'm sure he has pressed a button somewhere that needs to be "reset" to default system.
    New Friend:
  • 132 Answers
Press and hold first softkey during power on to "RESET to Factory Defaults" all waypoints will be lost. check the GPS, the actual antenna on arch (mushroom or hockey puck) is the green light flashing every 5 seconds? check at night, it is dim
Posted on Jan 17, 2010
    Scholar:
  • 76 Answers
If this is a "C" or "E" series unit, you can perform a factory reset by (starting with the unit off) powereing it on while holding down the first softkey. By that I mean the first key on the bottom of the display closest to the power button. Hold that first key until the unit finishes the reset countdown and begins to reboot. NOTE this will delete an saved waypoint that you may haveso if you have a lot of info stored that you need to keep, you can back it up by using a blank CF card and pressing the "Data" key and choosing "Archive and Transfer".
Posted on Sep 06, 2009
    Problem Solver:
  • 10 Answers
With the charts page up, start by hitting the find ship softkey at the bottom of the screen.If that find the boat on the chart all is good.If not you need to check you have a GPS fix. Go to GPS screen and see you are seeing satalites.
If all is good when you hit find ship and the boat disappears again from chart while underway you will need to go into the chart setup menu and see if the screen amplifier is turned off. If off turn on.This is first place to start. Hope that helps
Posted on Jun 15, 2009
How can I put sea talk to a raymarine sl70crc plus to a raymarine 70crcl plus at the same time
I doubt you can because they will share the same power and you may cause issues if there is a short circuit anywhere. Talk to RayMarine.
Mar 06, 2017 | Raymarine Boating
Raymarine Raydata
You can find very good new and used Raymarine equipment on Ebay for about 1/2 the price of retail.
Mar 06, 2014 | Raymarine E26011 Bt Triducer F/ Raydata...
I have changed my boat and have kept the ST2000 and S100 remote and the wireless base to fit on my new boat. Is it possible to get a wiring diagram to fit this to my new boat please
HI!
We have the same setup on our vessel.
Here's the link from Raymarine for instructions to install your base unit: http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=1020&PRODUCT=3036
(Click on Base Station & Controller installation)
And here is the link to your owners manual for your ST2000+:
http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=87&PRODUCT=19
(Click on 81130 6.pdf)
These contain all the wiring information you need to get it done!
Happy Boating!
Jan 24, 2011 | Raymarine ST2000 Plus Tiller Pilot A12005
We have a Raymarine ST8001 autopilot system that we are unable to get throught the calibration mode to set deviation. Our boat dealer mounted the fluxgate compass within 18" of the emgine which was too...
compass needles are affected by iron objects and can also be affected by field magnetism generated by current flowing through a wire .Bilge pumps , winch motors are heavy current drawers and they could affect the compass operation
while the voltage is low the field of the magnetism around the wire can influence the compass heading so check for any electronic apparatus wiring close to the unit ( radio , radar etc
it may be necessary to run the powers wires in an insulated sheath ( like coaxial cable or other insulated power cables) around sensitive equipment
talk with marine equipment installers to get better ideas as to prevent interference with the compass
Apr 04, 2017 | Raymarine Fluxgate Compass Module
Raymarine G-series. How do you reset. We have
Call Raymarine Tech Support or your installing dealer. The G series equipment is the cream of the Raymarine crop and troubleshooting it is not common knowledge even for dealers. Get your info right from the horse's mouth.
Jul 05, 2009 | Raymarine E120 Multifunction GPS Receiver
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
I require a Manual for a Apelco 365 fish Finder
Check out this site, on here they have a download for the manual you require,
www.retrevo.com/s/Raymarine-465-review-manual/id/556ci073/t/1-2/ - 52k - or go direct to www.raymarine.com
Regards
Alan Hood
ami-man
UK
Mar 12, 2009 | Boating
Auto pilot
difficult is it to install Raymarine 8002 autopilot in 270 Sea Ray
Jan 14, 2009 | Raymarine St8002 Smartpilot Autopilot...
Raymarine Ray 240 usa model
You cannot just reprogram your Raymarine to european standard.
This radio has been built and is licenced for using with USA frequency, in Europe his use will be limited to lower bands with no modification.
To be fully adapted to higher bands, the radio must be taken apart, and you need to bridge a contact on the main board.
The use of the radio after modifacion won't be legal in Europe.
Oct 03, 2008 | Raymarine Ray 240 Modular Vhf System
Raymarine gps sounder
This is a common problem if the GPS is hooked up to an electronic heading sensor such as an autopilot. If the heading sensor is not calibrated properly, the boat will appear to be facing the wrong direction.
If you have an autopilot, consult the installation guide and perform the sea trial procedures. That should get your boat lined up properly.
Jul 17, 2008 | Raymarine GPS
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
384 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
