Question about InFocus LP 600 Multimedia Projector
Mod.620 shuts dowd.
The unit shuts down after 15 to 30 of use.The lamp goes off,but fan continues to run.After a while,you can turn off and then back on the main switch.The unit comes on for another few minutes.I tried another lamp
but same thing.[the lamp I tried was a used lamp]I hane cleaned the two fans.Some one mentioned a reset timer.Where is it and how do you reset it?Please help!
  • deefly Mar 11, 2009
    my projector lights up but before it can go to full brightness it shuts down i replaced the bulb with what is suppose to be a new one wondering if new bulb could be defective how can i tell if so called new bulb is bad
    Brigadier General:
  • 3,614 Answers
Everytime that you use to change Lamp, the unit system timer must reset or setup again... You can see and change this option in the MENU SETTING using the remote control of the unit..
Posted on Jul 13, 2008
I have a sony kds 55A2000 and my lamp went out so i replaced it. and it startes up fan goes on and off . and tv shuts down light still blinks red? My optical block is getting a light green yellow tint but...
Lamp Fan should not cut off and on it should run at all times when TV is Turned on.Lamp Fan is designed to run when set is turned on to Keep Lamp Cool otherwise Lamp will burn up.
Yes Bad optical unit block could also cause set to shut down.But most of them will Play but with Dots,Green yellow tinit or Big blue Spots
Jun 23, 2011 | Sony KDS55A2000 55" HDTV
Optoma MovieTime: The Lamp that Won't stay on
its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
Aug 22, 2007 | Optoma MovieTime DV10 Multimedia Projector
LCD projector shuts off durning use
u have not mentioned how long u have been using this projector. either the lamp life is low or the circuitry protecting the lamp temperature is defective or even the air intake of the fan is inadequate, a filter is fitted for air flow if this is clogged or blocked, lamp temp will rise and unit shuts down. if lamp indicator is yellow or red it is time to change the lamp. if it is red - lamp is totally out, if u turn on the unit four times without replacing lamp, the unit simply wont turn on. one other possibility is power cable and power connections. check power cable too.
Apr 07, 2010 | Sharp Notevision PG-A10X Multimedia...
I have a Luxeon v1 that runs for about 1-2 hours and then shuts itself off. The bulb is off but the fan is still running. I am unable to turn off the projector and I have to unplug it from the outlet to...
First of all, DO NOT unplug the unit until the fan stops. The fan should continue to run until the lamp has cooled down completely. This is normal. If the unit is shutting down on its own, perhaps the fan is not working good enough. Check for debris in the fan area and be sure that there is enough ventilation to keep the unit cool. The shutdown may be a safety shutoff because of heat.
Check the fans and update this with what you find.
Nov 03, 2009 | Luxeon V1 Multimedia Projector
Lamp wont stay on. fan continues to work after lamp goes out. When power is turned on light comes on and fan starts working. with in a second or so the lamp turns off but fan continues to run.
Most likely you need to replace the lamp. It is possible the your lamp ballast is failing as it scales back to low-voltage DC drive, but more often than not this problem is traced to the lamp needing to be replaced.
Mar 29, 2009 | Office Equipment & Supplies
Cooling fan is loud . I'm going to replace the lamp in the unit because all 3 lamps are blinking on the front panel. Unit shuts down but I'm wondering if there is a seperate cooling fan in the back of the...
That's probably the Color Wheel you are hearing. When you turn the set on the color wheel has to run, one of the several things that has to happen for the set to come on. The color wheel sends a signal back to the control circuit to tell it it's running. If these sets fail to light the lamp they will shut off and try again, that's why you hear the color wheel start then wind down then start again. The set should try three times before it decides it's not going to be able to turn on.
One way you can tell the difference in the fan sound and color wheel sound is if you can get the set on, let it run for a little while so it gets warm, then when you turn it off the color wheel will start winding down but the fans will continue to run for a minute or two.
Mar 25, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Infocus mod.610/620 Lite pro
sounds like either a power supply issue, which will cost more than the unit is probably worth. or the thermo- sensor may be flaking out, which may not be too costly to repair.
then there may be bigger issues but i would guess 1 of the 2 mentioned
Jun 25, 2008 | Office Equipment & Supplies
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Television shuts down as if thermal problem, but cool
Shorted red driver trans shorted red pic tube defective focus/screen block any or all of these stk's on convergence module check the solder joints on convergence module
Jan 06, 2006 | Panasonic PT-40LC12 40" Rear Projection...
InFocus LP 600 Multimedia Projector Logo
151 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
