Question about Bosch Axxis WFL 2060 Front Load Washer
Filter I hear something in the washing machine when spins, how can I open the filter?
  • mattathome Aug 06, 2008
    Same with me, when the washer is spinning I hear a scraping sound. I just know there's some loose change in there somewhere. And I want that money back.
    President:
  • 1,462 Answers
If you have a foreign object in the washer, this can not be removed by checking the filter
remove the heater and you can see into the gap between drum and tub and remove whatever is there
Posted on Jul 13, 2008
Didn't drain. Won't spin.
Hi Kat, let's see if I can help your with this. The washer will not spin when it senses water inside so we'll start first with the drain. When the machine was finished washing, did you hear the drain pump attempting to discharge water? Try selecting the "Spin Only" or "Rinse and Spin" cycle, you should be able to hear whether or not the drain pump is attempting to operate. If you do hear it running, but the water is not draining, it is possible that the drain filter is clogged. If you need instructions on how to clean the filter let me know. Otherwise, we'll move to the next step.
Mar 07, 2015 | Samsung WF203ANW Front Load Washer
Washing machine gets stuck each time on Rinse, Drain or Spin cylce and can't open door!
the drain pump cant get the water out of the machine check it and also check the filter maybe something stuck in it
Feb 10, 2014 | Tricity Bendix AW1000W Front Load Washer
Washing mahine stops after one minute
put it on the spin cycle and open the filter if it's the belt you will surely hear the motor spinning if not then it's not the belt
Feb 10, 2014 | AEG Lavamat 72640 Front Load Washer
How can I access filter/pump
it depends on the make of machine. Many have a small hatch on the bottom front of the machine that allows easy access to the filter. If you open this, there is usually a simple screw to open the filter and hoik any gunge and coins out. you need to put something under the filter when you open it up as a small amount of water will spill ou.t
Mar 08, 2012 | Washing Machines
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
Water does not come to the washing chamber
Switch the machine on when the room is quiet
Dial up a cool wash hit the start button then listen while you remove the power you should hear water falling into the drum
If there is power to the fill valve ? then you need to put a meter across the terminals to check for resistance , no resistance means an open circuit coil and a the valve will not open
Jan 05, 2010 | Washing Machines
Bosch 2460 washime machine. washed, will not drain r spin
i think thew buzz you hear maybe something stuck in the pump impellor. remove filter and check
Jul 23, 2008 | Bosch Logixx WFT 2806 Front Load...
Loud whirring sound
no problem withthe water they sometimes use a water ring for balance, or you may be hearing water reaming in the pump and hose areaa, its always there. as far as not spinning completly you may need to replace the belt or the idler(tension pulley), two 5/16 screw along the very bottom of unit will gai you access to see inside the machine
Apr 04, 2008 | Amana DLW330RA Top Load Washer
Washer will not Spin during SPIN CYCLES
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
57 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
