Question about Wise Solutions Wise For Windows Installer 6 Enterprise Edition for PC
Windows installer problem
An error message crops up state\ing" your system is in safe mode or windows installer is not installed properly. contact your service person"
  • 1,879 Answers
Greetings,
Reinstall the software.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jul 13, 2008
How i remove the hppusg.exe-.net framework initialization error
Hi Kabir,
1. Were there any changes made on the computer prior to the issue?
2. What is the complete and exact error message?
3. Have you installed any HP software/hardware recently?
Method 1:
Step 1:
Try to restart your computer in Safe mode and check if the problem persists.
A description of the Safe Mode Boot options in Windows XP
http://support.microsoft.com/kb/315222
If it works fine in safe mode try performing a clean boot to find the root cause
Step 2:
Refer the article for steps on how to start your computer in clean boot state.
How to configure Windows XP to start in a "clean boot" state
http://support.microsoft.com/kb/310353
Note: Also, see the section on how to return your computer to a Normal startup mode by following the steps under "Steps to configure Windows to use a Normal startup state".
Method 2:
If you have installed HP software /hardware, I suggest you to update the drivers for the device and check if it helps:
How to manage devices in Windows XP
http://support.microsoft.com/kb/283658
Jan 06, 2018 | The Computers & Internet
Hi, I have a windows 7 ultimate 32 bit. And when
Try first getting in via safe mode (Hit F8 when booting and then choose Safe Mode) - then use system restore to revert to a previous working state.
Aug 10, 2013 | Computers & Internet
I have windows xp an error message box pops up that says at the top message from webpage [object error] it wont go away after xing it hitting ok or alt control delete. Everthing is locked up depending on...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer this may vary depending on your computer and operating system If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details or You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps. Hope it helps.
Jan 05, 2013 | Computers & Internet
I have a dell laptop inspiron 1525. i can turn it on, and sign in to my user area, but it freezes within a minute. pressing f8 whilst turning the laptop on and clicking "startup repair" proves...
First go safe mode by pressing F8 key when your computer start.
Then windows run in safe mode click run and type msconfig then enter a winodws apear to show some lists choose startup items and disable all startup iteams and reboot it and now check it is working ok or not ?
after scan your computer for virus .
Dec 28, 2010 | Dell Inspiron 1525 Notebook
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Msi is not working.
Have you tried reinstalling/upgrading your Windows Installer? Link below...
Windows Installer 3.1
Nov 17, 2008 | Computers & Internet
Blue colour background saying it is the stop error screen.
The fix from Microsoft's website:
To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail:
  1. Start Windows in Safe mode. To do so:
    1. Restart the computer, and then press F8 while the computer starts.
    2. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER.
    3. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode.
  2. In the message that states that Windows is running in Safe mode, click Yes.
  3. Click Start, click Run, type msinfo32 in the Open box, and then click OK.
  4. Under System Summary, expand Components, and then click Display.
  5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf.
  6. Quit the System Information utility.
  7. Click Start, right-click My Computer, and then click Properties.
  8. Click the Hardware tab, and then click Device Manager.
  9. Expand Display adapters, right-click the display adapter, and then click Uninstall.
  10. Click OK.
  11. Click Start, click Run, type cmd, and then click OK.
  12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
    ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old
  13. Close all open windows, and then restart the computer in the typical manner.
  14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware.
  15. When the Found New Hardware Wizard starts, click Cancel.
    If you receive a stop error after you remove the updated display drivers, restart the computer and use the Last Known Good Configuration option. To do this, restart the computer, and then press the F8 key while the computer starts. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Last Known Good Configuration, and then press ENTER.
    If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.
  16. Obtain and install the latest drivers for your display adapter.For information about how to contact your computer manufacturer, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
I GET ERROR MESSAGE STATING INSTALL IS INCOMPLETE NEED DISC
Hello, Follow the instruction:
Press power button and enter to boot configuration menu (you can enter there by pressing F8, F9, or CTRL it depends on your motherboard model). If you see there:
Safe mode
Safe mode with networking...
You are in right place. Then find there "Last good known configuration" button and press it. If problem is not solved make it 2 or 3 times.
Sep 06, 2008 | Microsoft Windows Vista Ultimate Edition
200 ARC
Try and use it in 'safe mode' by pressing F8 in advanced startup options.
Then do the system restore.
Sorry if it dosen't help but i can't really reply in fully on a forum.
Jun 29, 2008 | Computers & Internet
UNABLE TO REACH DESKTOP
loadTOCNode(1, 'symptoms');-------------------------------------SYMPTOMS:------------------------------------
When you restart your computer after you install Windows XP Service Pack 1 (SP1), your computer may generate the following Stop error message:
STOP: 0x00000050 (0x8872A990, 0x00000001, 0x804F35D7, 0x00000000)
PAGE_FAULT_IN_NON-PAGED_AREA
----------------------------------------CAUSE:-----------------------------------------
loadTOCNode(1, 'cause'); This problem may occur if there is a conflict between Windows XP SP1 and the display adapter drivers that are currently installed.
------------------------------------SOLUTION :---------------------------------------
loadTOCNode(1, 'resolution'); To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail: 1. Start Windows in Safe mode. To do so: a. Restart the computer, and then press F8 while the computer starts. b. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER. c. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode. 2. In the message that states that Windows is running in Safe mode, click Yes. 3. Click Start, click Run, type msinfo32 in the Open box, and then click OK. 4. Under System Summary, expand Components, and then click Display. 5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf. 6. Quit the System Information utility. 7. Click Start, right-click My Computer, and then click Properties. 8. Click the Hardware tab, and then click Device Manager. 9. Expand Display adapters, right-click the display adapter, and then click Uninstall. 10. Click OK. 11. Click Start, click Run, type cmd, and then click OK. 12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old 13. Close all open windows, and then restart the computer in the typical manner. 14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware. 15. When the Found New Hardware Wizard starts, click Cancel.
If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.16.Obtain and install the latest drivers for your display adapter.For information about how to contact computer hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi - (Technical Associate)
May 07, 2008 | Compaq Armada 1700 Notebook
Open Questions:
Starwars Battlefront 2: Wont Install I just finished downloading Starwars Battlefront 2 from: http://www.warez-bb.org/viewtopic.php?t=5343241&highlight= It says I need these requirements to play: (The words in the brackets are what I have) Operating system: Windows 2000/XP (Windows XP) Processor: Pentium 4 1.5 GHz (Genuine Intel(R) CPU 2140 @ 1.60GHz [2 CPUs]) Memory: 256 MB (1024MB RAM) Video: 64 MB (512MB) Sound card: compatible with DirectX 9.0c (DirectX 9.0c ) Available at Railway: 5.5 GB <- What does this mean? CD-ROM speed: 8x <- How do I check? Do I meet the requirements? I extracted it; opened up the file and inside there was 4 files: Disk1(712,674kb) Disk1(1kb) Disk2(367,454kb) Disk2(1kb) They are all MDF files. I open either of the Disk2 files and it has junk like DirectX, Docs, some setup-2.bin file? I open either of the Disk1 files and "Starwars Battlefront 2 Autorun" opens, it has four options, they're all in a very weird language, and only 2 of them are clickable.. The second one gives me this: ýòàïû çàïóñêà èãðû 1 - óñòàíîâèòå èãðó. 2 - ïåðåçàãðóçèòå êîìïüþòåð. 3 - çàïóñòèòå èãðó, ïðè ýòîì ïîÿâèòñÿ äèàëîãîâîå îêíî. 4 - íàæìèòå êíîïêó KPAK è çàêðîéòå ýòî îêíî, íàæàâ êðåñòèê â ïðàâîì âåðõíåì óãëó îêíà. 5 - èãðà çàïóñòèòüñÿ àâòîìàòè÷åñêè. I think it's a readme.. The first option opens an installer.. it's in that language.. I run threw the installer and it begins to installer, but halfway threw I get an popup.. I think it's asking me where I want to save something.. It has a bar where i'm suppose to put a path, the default is G:\, when I click ok is has ???? "setup-2.bin" ???? "G:\" ????. The ?'s meaning the random language.. I click browse and click on other options but it has the same result for everything.. Please help somebody!
May 06, 2010 | Wise Solutions Wise For Windows Installer...
Wise Solutions Wise For Windows Installer 6 Enterprise Edition for PC Logo
91 people viewed this question
Top Wise Solutions Computers & Internet Experts
David Payne
David Payne
Are you a Wise Solutions Computer and Internet Expert? Answer questions, earn points and help others
