Question about Dometic 57915531 Air Conditioner
Dometic ac I have a ALJO travel trailer with a DOMETIC ac unit M# 57915 runs perfect but started to leak from the celing last time out. Is there a drain line for the top unit that needs cleaned out. Thanks Colby in Tampa fl. colbyklouda@verizon.net
  • 499 Answers
If the unit is not ducted, the evaporator coil drain pan sits under the coil and shallow channels in the unit that allow the condensate to migrate to the condenser coil which has a splash ring on the condenser fan blade, that ring slings the condensate upon the hot condenser coil thus evaporating the condensate while help condense and sub cool the refrigerant, very often the channels are clogged with the results of condensate and dust etc accumulating, the evaporator coil itself also may be dirty and obstructed restricting the air flow across the evaporator coil
thus resulting in a low load upon the evaporator coil and icing which will cause dripping, simply being dirty will do it as well it really has to be seen to be sure exactly why your units leaking and from where, rarely they do rust out but it happens.
Posted on Aug 27, 2013
Remove the lower assembly and tighten the bolts that hold ac down to coach or pull shroud and check to make sure unit is not frezing up due to dirt
Posted on Aug 23, 2008
I have a Dometic DuoTherm ac/furnace unit in an rv. The thermostat got knocked off the wall and now the ac nor the furnace will work. Fan works in manual position only. What could be wrong?
When the thermostat was knocked off it may have damaged the wiring. I would start by checking continuity of all wires from thermostat to unit.
Feb 15, 2015 | Dometic Rooftop RV Air Conditioner
Dometic 57912
You may have a week cap. just pick up a new one and also install a hard start kit. should solve your problem. worst case you have a bad compressor.
Jan 22, 2014 | Dometic Rooftop RV Air Conditioner
Need instructions on how to light a rv Dometic refrigerator-
Go to this link and download 2600 PDF, last few pages are operation.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Operation--Installation-Manuals/
Jun 08, 2010 | Dometic RM2620 Refrigerator
Dometic fridge. cooling it while traveling
If the trailer have good shocks absorbers, is posible traver with the unit on 12volts conection.
Aug 11, 2009 | Refrigerators
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Ac blowing breaker
The unit will draw more current when hot. Check rating of the breaker against the rating recommended by the manufacturer.
Jun 16, 2009 | Dometic Rooftop RV Air Conditioner
Dometic RM2652 will not cool on A/C or propane, I've checked fuses, and AC to refer. I opened the access panel on outside of Travel Trailer, and there is yellow powder on bottom, and some on heating tube....
Ammonia is just what you a re smelling as the coolant is ammonia based Your cooling unit has leaked and is done for- Sorry I had to be the one to tell you
2 choices Replace the refer or Replace the coiling unit, I would suggest replacing the refer and having a new warranty
Jun 07, 2009 | Dometic RM2652 Refrigerator
Dometic 57915531 Air Conditioner Logo
257 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
