Question about Jensen CD510K CD Player
Cut wires i just brought a 1999 ford windstar . i would like to upgrade my radio,but the last person who had it cut the plugs off for the radio and i can't find a wiring diagram to install a new one
    Problem Solver:
  • 3 Answers
Or go to Best Buy and have them sell you the plugs for the factory wiring side of the stereo and replace them
Posted on Dec 17, 2008
  • 132 Answers
Well, beeing ford has like 23 diffrent harnesses this may be a tough one, call 1-800-SCOSCHE and adk them :)
Posted on Jul 16, 2008
I need a radio wiring diagram for a 2003 ford windstar
Which diagrams do you need?...if it is to install an aftermarket deck, get an adapter so u dont cut into the factory wiring harness..the adapter plugs into the factory plug and allows u to solder the aftermarket radio wires to the other side of it.I have attached a link to where u can get the adapters...unfortunatly this wont allow me to send u my radio schematics that are in PDF format.
Car Stereo Installation Parts for2003 FORD WINDSTAR
Mar 08, 2015 | 2003 Ford Windstar
My boyfriend bought me a new cp player deck for my 99 windstar but none of the wires that were already there match anything that they should be how do i hook it up then>
The plugs will be different and the wiring is different colour, should get installed by professional. If you want to do it yourself you will need to cut off the plug and work out which wire goes where. Reply if you need a rough guide to assist you.
Aug 16, 2011 | 1999 Ford Windstar
Wires for radio were cut off plug before I got vehicle now I don't know what wire goes to what. My van is a 1996 ford windstar the radio was gone when I bought the van can you help?
ok here is the wire colors and what they are for.
1996 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
May 25, 2010 | Car Audio & Video
Need wiring guide for replacing stock radio 1996 ford windstar with Dual Model XD 1222 radio have harness still need wiring assistance
I would get an adapter harness that will plug into your existing vehicle plug, and the wires are color coded to match up to most aftermarket stereos. You could check e-Bay, or a local automotive audio store for the adapter harness.
May 10, 2010 | 1996 Ford Windstar
Radio wires differ from the speaker to the radio
This is the most common problem with self installs.The best thing to do is to get the car radio installation plug,it will plug into the factory plug for your factory radio and will give you a color coded pigtail to wire into that usually matches up perfectly with new aftermarket car radios.If the wires are already cut then you best bet is to extend the wires so that they are easy to work with hookup the power,ground,antenna and try dirrerent combos to isolate each speaker and label the wires accordingly.
Jan 01, 2010 | 1998 Ford Windstar
Wiring trailer lights for 2003 Windstar
To do it correctly and permanantly, cut the wire you want to splice into, then solder the new wire in with the old wires. Make sure to heat shrink. Less permanant, is to find some wire splicers that attach to the existing wire with a little tab.
Jul 02, 2009 | 1999 Ford Windstar
Shangeing radios need to know what colors go to what 1999 ford winstar
The colors actually should match up. If not there would be a diagram online. Just search for the vehicle and put in radio diagram.
Jun 12, 2009 | 1999 Ford Windstar
1999-2003 Ford Windstar radio removal procedure
remove the trim around the radio face be careful not to break it, it should snap off its a delicate proceedure take radio face plate off ( if equipped) radio should come out
Nov 09, 2008 | 2003 Ford Windstar
Engine light on my 1999 windstar is blinking
the windstars are very bad for cracked ignition coils, to check you have to remove the coil, remove spark plug wires from coil, disconnect main harness from coil and remove the 3 7mm bolts that hold it in place, once it is out inspect it for cracks, if it is the coil expect to pay around $105 for a new one from your Ford dealer
Sep 25, 2008 | 1999 Ford Windstar
Radio wire schematics
Theres some websites out there that should have the wiring diagrams you need. Just google Ford Windstar 1999 Radio wiring diagrams.
I found one for my 1994 when I owned it. I'm sure they carry this particular vehicle as well.
Jun 13, 2008 | 1999 Ford Windstar
Jensen CD510K CD Player Logo
144 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
