posted by jpatton82 on Jul 13, 2008
OK-So it turns itself on and off-It channel surfs on its own-It raises and lowers the volume on its own at will--Keeps popping up the menu, and sometimes pops up a menu that seems to be factory settings like tube type and things of this nature, not accessible via the regular set up menu---what gives? This thing is only about 18 months old-I called RCA and they were frickin clueless..
Comment by jpatton82, posted on Jul 28, 2008
Well, turns out the problem was the small signal board-They want $600 to replace---I only piad $800 for the TV, less than 2 years ago-RCA is a piece of ****--I won't buy another one! Thanks for the help though
Best Solution
posted on Jul 20, 2008
Hello jpatton82,
Don't call a priest just yet! :D
What I want you to di is first unplug the TV. Then find the connector for the front panel controls, and unplug it (You may need the schematic to find this). The take the fascia if the TV off to expose the front control board, and the remove the retaining screws and take it off. Once the controller if detached from the TV, clean it with circuit cleaner solvent (This should remove any contaminates from the board and contacts). Once the board is dry reattach (and plugged back in to the circuit board) it and put the fascia back on. Turn on the TV and see if this works, if not the check the integrated circuit uses the control board as input check and see if its bias voltages match what is in the book, If the IC is defective replace it if you find the voltages are normal then try to see if their might be IR signals from other sources that could produce these results..
This should help for now,
Contact me via this post if none of these tasks work.
Thank you,
Shuttle83
Thank you,
Shuttle83
Rating Locked! (?) jpatton82 has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for RCA HD52W59 HDTV Television
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
Having problems with projection...
Projection has triple images... Answer This...
Repair Service
Find Projection TV Repairman Near You:
Find Parts
